cesium-native 0.62.0
CesiumGltf::AccessorSpec::ComponentType Struct Reference
Known values for The datatype of the accessor's components. More...
#include <CesiumGltf/AccessorSpec.h>
static constexpr int32_t BYTE = 5120
 BYTE (5120)
static constexpr int32_t UNSIGNED_BYTE = 5121
 UNSIGNED_BYTE (5121)
static constexpr int32_t SHORT = 5122
 SHORT (5122)
static constexpr int32_t UNSIGNED_SHORT = 5123
 UNSIGNED_SHORT (5123)
static constexpr int32_t INT = 5124
 INT (5124)
static constexpr int32_t UNSIGNED_INT = 5125
 UNSIGNED_INT (5125)
static constexpr int32_t INT64 = 5134
 INT64 (5134)
static constexpr int32_t UNSIGNED_INT64 = 5135
 UNSIGNED_INT64 (5135)
static constexpr int32_t FLOAT = 5126
 FLOAT (5126)
static constexpr int32_t DOUBLE = 5130
 DOUBLE (5130)
Definition at line 27 of file AccessorSpec.h.
◆ BYTE
int32_t CesiumGltf::AccessorSpec::ComponentType::BYTE = 5120
BYTE (5120)
Definition at line 29 of file AccessorSpec.h.
◆ DOUBLE
int32_t CesiumGltf::AccessorSpec::ComponentType::DOUBLE = 5130
DOUBLE (5130)
Definition at line 56 of file AccessorSpec.h.
◆ FLOAT
int32_t CesiumGltf::AccessorSpec::ComponentType::FLOAT = 5126
FLOAT (5126)
Definition at line 53 of file AccessorSpec.h.
◆ INT
int32_t CesiumGltf::AccessorSpec::ComponentType::INT = 5124
INT (5124)
Definition at line 41 of file AccessorSpec.h.
◆ INT64
int32_t CesiumGltf::AccessorSpec::ComponentType::INT64 = 5134
INT64 (5134)
Definition at line 47 of file AccessorSpec.h.
◆ SHORT
int32_t CesiumGltf::AccessorSpec::ComponentType::SHORT = 5122
SHORT (5122)
Definition at line 35 of file AccessorSpec.h.
◆ UNSIGNED_BYTE
int32_t CesiumGltf::AccessorSpec::ComponentType::UNSIGNED_BYTE = 5121
Definition at line 32 of file AccessorSpec.h.
◆ UNSIGNED_INT
int32_t CesiumGltf::AccessorSpec::ComponentType::UNSIGNED_INT = 5125
UNSIGNED_INT (5125)
Definition at line 44 of file AccessorSpec.h.
◆ UNSIGNED_INT64
int32_t CesiumGltf::AccessorSpec::ComponentType::UNSIGNED_INT64 = 5135
Definition at line 50 of file AccessorSpec.h.
◆ UNSIGNED_SHORT
int32_t CesiumGltf::AccessorSpec::ComponentType::UNSIGNED_SHORT = 5123
Definition at line 38 of file AccessorSpec.h.
