A typed view into a buffer view that contains raw binary data. More...
#include <CesiumGltf/AccessorSpec.h>
Classes | |
| struct | ComponentType |
| Known values for The datatype of the accessor's components. More... | |
| struct | Type |
| Known values for Specifies if the accessor's elements are scalars, vectors, or matrices. More... | |
Public Member Functions inherited from CesiumGltf::NamedObject | |
| Calculates the size in bytes of this object, including the contents of all collections, pointers, and strings. Calling this method may be slow as it requires traversing the object's entire structure. | |
| int32_t | bufferView = -1 |
| The index of the bufferView. | |
| int64_t | byteOffset = 0 |
| The offset relative to the start of the buffer view in bytes. | |
| int32_t | componentType = ComponentType::BYTE |
| The datatype of the accessor's components. | |
| bool | normalized = false |
| Specifies whether integer data values are normalized before usage. | |
| int64_t | count = int64_t() |
| The number of elements referenced by this accessor. | |
| std::string | type = Type::SCALAR |
| Specifies if the accessor's elements are scalars, vectors, or matrices. | |
| std::vector< double > | max |
| Maximum value of each component in this accessor. | |
| std::vector< double > | min |
| Minimum value of each component in this accessor. | |
| std::optional< CesiumGltf::AccessorSparse > | sparse |
| Sparse storage of elements that deviate from their initialization value. | |
Public Attributes inherited from CesiumGltf::NamedObject | |
| std::string | name |
| The user-defined name of this object. | |
| static constexpr const char * | TypeName = "Accessor" |
| AccessorSpec ()=default | |
| This class is not meant to be instantiated directly. Use Accessor instead. | |
Friends | |
| struct | Accessor |
Definition at line 18 of file AccessorSpec.h.
Definition at line 183 of file AccessorSpec.h.
friend |
Definition at line 203 of file AccessorSpec.h.
| int32_t CesiumGltf::AccessorSpec::bufferView = -1 |
The index of the buffer view. When undefined, the accessor MUST be initialized with zeros; sparse property or extensions MAY override zeros with actual values.
Definition at line 93 of file AccessorSpec.h.
| int64_t CesiumGltf::AccessorSpec::byteOffset = 0 |
This MUST be a multiple of the size of the component datatype. This property MUST NOT be defined when bufferView is undefined.
Definition at line 101 of file AccessorSpec.h.
| int32_t CesiumGltf::AccessorSpec::componentType = ComponentType::BYTE |
Known values are defined in ComponentType.
UNSIGNED_INT type MUST NOT be used for any accessor that is not referenced by mesh.primitive.indices.
Definition at line 112 of file AccessorSpec.h.
| int64_t CesiumGltf::AccessorSpec::count = int64_t() |
The number of elements referenced by this accessor, not to be confused with the number of bytes or number of components.
Definition at line 130 of file AccessorSpec.h.
| std::vector<double> CesiumGltf::AccessorSpec::max |
Array elements MUST be treated as having the same data type as accessor's componentType. Both min and max arrays have the same length. The length is determined by the value of the type property; it can be 1, 2, 3, 4, 9, or 16.
normalized property has no effect on array values: they always correspond to the actual values stored in the buffer. When the accessor is sparse, this property MUST contain maximum values of accessor data with sparse substitution applied.
Definition at line 154 of file AccessorSpec.h.
| std::vector<double> CesiumGltf::AccessorSpec::min |
normalized property has no effect on array values: they always correspond to the actual values stored in the buffer. When the accessor is sparse, this property MUST contain minimum values of accessor data with sparse substitution applied.
Definition at line 169 of file AccessorSpec.h.
| bool CesiumGltf::AccessorSpec::normalized = false |
Specifies whether integer data values are normalized (true) to [0, 1] (for unsigned types) or to [-1, 1] (for signed types) when they are accessed. This property MUST NOT be set to true for accessors with FLOAT or UNSIGNED_INT component type.
Definition at line 122 of file AccessorSpec.h.
| std::optional<CesiumGltf::AccessorSparse> CesiumGltf::AccessorSpec::sparse |
Definition at line 175 of file AccessorSpec.h.
| std::string CesiumGltf::AccessorSpec::type = Type::SCALAR |
Definition at line 139 of file AccessorSpec.h.
Definition at line 22 of file AccessorSpec.h.
