CesiumGltf::NamedObject Struct Reference
The base class for objects in a glTF that have a name. More...
#include <CesiumGltf/NamedObject.h>
Inheritance diagram for CesiumGltf::NamedObject:
CesiumUtility::ExtensibleObject CesiumGltf::AccessorSpec CesiumGltf::Animation CesiumGltf::BufferSpec CesiumGltf::BufferView CesiumGltf::Camera CesiumGltf::ExtensionKhrImplicitShapesShape CesiumGltf::ExtensionModelKhrMaterialsVariantsValue CesiumGltf::ExtensionModelMaxarMeshVariantsValue CesiumGltf::ExternalAsset CesiumGltf::File CesiumGltf::ImageSpec CesiumGltf::Layer CesiumGltf::Light CesiumGltf::Material CesiumGltf::Mesh CesiumGltf::Node CesiumGltf::Sampler CesiumGltf::Scene CesiumGltf::Shape CesiumGltf::Skin CesiumGltf::Texture
std::string name
A named object is also an CesiumUtility::ExtensibleObject.
Definition at line 14 of file NamedObject.h.
int64_t CesiumGltf::NamedObject::getSizeBytes ( ) const
Definition at line 28 of file NamedObject.h.
◆ name
std::string CesiumGltf::NamedObject::name
This is not necessarily unique, e.g., an accessor and a buffer could have the same name, or two accessors could even have the same name.
Definition at line 21 of file NamedObject.h.
