CesiumGltf::AccessorSparse Struct Referencefinal
Sparse storage of accessor values that deviate from their initialization value. More...
#include <CesiumGltf/AccessorSparse.h>
Inheritance diagram for CesiumGltf::AccessorSparse:
int64_t count = int64_t()
 Number of deviating accessor values stored in the sparse array.
CesiumGltf::AccessorSparseIndices indices
 An object pointing to a buffer view containing the indices of deviating accessor values. The number of indices is equal to count. Indices MUST strictly increase.
CesiumGltf::AccessorSparseValues values
 An object pointing to a buffer view containing the deviating accessor values.
static constexpr const char * TypeName = "AccessorSparse"
Definition at line 17 of file AccessorSparse.h.
int64_t CesiumGltf::AccessorSparse::getSizeBytes ( ) const
Definition at line 48 of file AccessorSparse.h.
◆ count
int64_t CesiumGltf::AccessorSparse::count = int64_t()
Definition at line 27 of file AccessorSparse.h.
◆ indices
CesiumGltf::AccessorSparseIndices CesiumGltf::AccessorSparse::indices
Definition at line 34 of file AccessorSparse.h.
const char* CesiumGltf::AccessorSparse::TypeName = "AccessorSparse"
Definition at line 22 of file AccessorSparse.h.
◆ values
CesiumGltf::AccessorSparseValues CesiumGltf::AccessorSparse::values
Definition at line 40 of file AccessorSparse.h.
