A view on a PropertyAttribute. More...
#include <CesiumGltf/PropertyAttributeView.h>
| PropertyAttributeView (const Model &model, const PropertyAttribute &propertyAttribute) noexcept | |
| Construct a PropertyAttributeView. | |
| PropertyAttributeViewStatus | status () const noexcept |
| Gets the status of this property attribute view. | |
| const std::optional< std::string > & | name () const noexcept |
| Gets the name of the property attribute being viewed. Returns std::nullopt if no name was specified. | |
| const Class * | getClass () const noexcept |
| Gets the Class that this property attribute conforms to. | |
| const ClassProperty * | getClassProperty (const std::string &propertyId) const |
| Finds the ClassProperty that describes the type information of the property with the specified id. | |
| template<typename T, bool Normalized = false> | |
| PropertyAttributePropertyView< T, Normalized > | getPropertyView (const MeshPrimitive &primitive, const std::string &propertyId) const |
| Gets a PropertyAttributePropertyView that views the data of a property stored in the PropertyAttribute. | |
| template<typename Callback> | |
| void | getPropertyView (const MeshPrimitive &primitive, const std::string &propertyId, Callback &&callback) const |
| Gets a PropertyAttributePropertyView through a callback that accepts a property id and a PropertyAttributePropertyView that views the data of the property with the specified id. | |
| void | forEachProperty (const MeshPrimitive &primitive, Callback &&callback) const |
| Iterates over each property in the PropertyAttribute with a callback that accepts a property id and a PropertyAttributePropertyView to view the data stored in the PropertyAttributeProperty. | |
This should be used to get a PropertyAttributePropertyView of a property in the property attribute. It will validate the EXT_structural_metadata format and ensure PropertyAttributePropertyView does not access data out of bounds.
Definition at line 72 of file PropertyAttributeView.h.
noexcept |
| model | The glTF that contains the property attribute's data. |
| propertyAttribute | The PropertyAttribute from which the view will retrieve data. |
This method will validate the EXT_structural_metadata format to ensure PropertyAttributePropertyView retrieves the correct data. T must be a scalar with a supported component type (int8_t, uint8_t, int16_t, uint16_t, float), a glm vecN composed of one of the scalar types, or a PropertyArrayView containing one of the scalar types.
If the property is invalid, an empty PropertyAttributePropertyView with an error status will be passed to the callback. Otherwise, a valid property view will be passed to the callback.
| primitive | The id of the property to retrieve data from |
| callback | A callback function that accepts property id and PropertyAttributePropertyView |
| Callback | The type of the callback function. |
Definition at line 329 of file PropertyAttributeView.h.
inlinenoexcept |
Definition at line 107 of file PropertyAttributeView.h.
| const ClassProperty * CesiumGltf::PropertyAttributeView::getClassProperty | ( | const std::string & | propertyId | ) | const |
| propertyId | The id of the property to retrieve the class for. |
This method will validate the EXT_structural_metadata format to ensure PropertyAttributePropertyView retrieves the correct data. T must be a scalar with a supported component type (int8_t, uint8_t, int16_t, uint16_t, float), a glm vecN composed of one of the scalar types, or a glm matN containing one of the scalar types.
If T does not match the type specified by the class property, this returns an invalid PropertyAttributePropertyView. Likewise, if the value of Normalized does not match the value of ClassProperty::normalized for that class property, this returns an invalid property view. Only types with integer components may be normalized.
| T | The C++ type corresponding to the type of the data retrieved. |
| Normalized | Whether the property is normalized. Only applicable to types with integer components. |
| primitive | The target primitive |
| propertyId | The id of the property to retrieve data from |
Definition at line 144 of file PropertyAttributeView.h.
If the property is somehow invalid, an empty PropertyAttributePropertyView with an error status will be passed to the callback. Otherwise, a valid property view will be passed to the callback.
| callback | A callback function that accepts a property id and a PropertyAttributePropertyView |
Definition at line 192 of file PropertyAttributeView.h.
inlinenoexcept |
Definition at line 97 of file PropertyAttributeView.h.
inlinenoexcept |
Indicates whether the view accurately reflects the property attribute's data, or whether an error occurred.
Definition at line 91 of file PropertyAttributeView.h.
