CesiumGltf::PropertyAttributeProperty Struct Referencefinal
An attribute containing property values. More...
#include <CesiumGltf/PropertyAttributeProperty.h>
Inheritance diagram for CesiumGltf::PropertyAttributeProperty:
std::string attribute
 The name of the attribute containing property values.
std::optional< CesiumUtility::JsonValue > offset
 An offset to apply to property values. Only applicable when the component type is FLOAT32 or FLOAT64, or when the property is normalized. Overrides the class property's offset if both are defined.
std::optional< CesiumUtility::JsonValue > scale
 A scale to apply to property values. Only applicable when the component type is FLOAT32 or FLOAT64, or when the property is normalized. Overrides the class property's scale if both are defined.
std::optional< CesiumUtility::JsonValue > max
 Maximum value present in the property values. Only applicable to SCALAR, VECN, and MATN types. This is the maximum of all property values, after the transforms based on the normalized, offset, and scale properties have been applied.
std::optional< CesiumUtility::JsonValue > min
 Minimum value present in the property values. Only applicable to SCALAR, VECN, and MATN types. This is the minimum of all property values, after the transforms based on the normalized, offset, and scale properties have been applied.
static constexpr const char * TypeName = "PropertyAttributeProperty"
Definition at line 16 of file PropertyAttributeProperty.h.
int64_t CesiumGltf::PropertyAttributeProperty::getSizeBytes ( ) const
Definition at line 64 of file PropertyAttributeProperty.h.
◆ attribute
std::string CesiumGltf::PropertyAttributeProperty::attribute
Definition at line 26 of file PropertyAttributeProperty.h.
◆ max
std::optional<CesiumUtility::JsonValue> CesiumGltf::PropertyAttributeProperty::max
Definition at line 48 of file PropertyAttributeProperty.h.
◆ min
std::optional<CesiumUtility::JsonValue> CesiumGltf::PropertyAttributeProperty::min
Definition at line 56 of file PropertyAttributeProperty.h.
◆ offset
std::optional<CesiumUtility::JsonValue> CesiumGltf::PropertyAttributeProperty::offset
Definition at line 33 of file PropertyAttributeProperty.h.
◆ scale
std::optional<CesiumUtility::JsonValue> CesiumGltf::PropertyAttributeProperty::scale
Definition at line 40 of file PropertyAttributeProperty.h.
const char* CesiumGltf::PropertyAttributeProperty::TypeName = "PropertyAttributeProperty"
Definition at line 21 of file PropertyAttributeProperty.h.
