A view of the data specified by a PropertyAttributeProperty. More...
Ideally, property attribute properties can be initialized as vertex attributes in the target rendering context. However, some runtime engines do not allow custom vertex attributes. To compensate, this view can be used to sample the property attributes property via vertex index.
| ElementType | The type of the elements represented in the property view |
| Normalized | Whether or not the property is normalized. If normalized, the elements can be retrieved as normalized floating-point numbers, as opposed to their integer values. |
Definition at line 104 of file PropertyAttributePropertyView.h.
