3#include <CesiumGeospatial/BoundingRegion.h>
4#include <CesiumGeospatial/Ellipsoid.h>
5#include <CesiumGeospatial/GlobeRectangle.h>
6#include <CesiumGltfContent/Library.h>
43 static std::optional<glm::dmat4x4>
67 static std::optional<glm::dmat4x4>
79 const glm::dmat4x4& newTransform);
95 const glm::dmat4x4& rootTransform);
117 const glm::dmat4x4& rootTransform);
139 const glm::dmat4& transform,
152 static std::vector<std::string_view>
162 static std::vector<std::string_view>
203 const std::vector<int32_t>& extraUsedTextureIndices = {});
215 const std::vector<int32_t>& extraUsedSamplerIndices = {});
227 const std::vector<int32_t>& extraUsedImageIndices = {});
239 const std::vector<int32_t>& extraUsedAccessorIndices = {});
251 const std::vector<int32_t>& extraUsedBufferViewIndices = {});
263 const std::vector<int32_t>& extraUsedBufferIndices = {});
275 const std::vector<int32_t>& extraUsedMeshIndices = {});
287 const std::vector<int32_t>& extraUsedMaterialIndices = {});
348 std::optional<RayGltfHit>
hit;
373 bool cullBackFaces =
true,
374 const glm::dmat4x4& gltfTransform = glm::dmat4(1.0));
A ray that extends infinitely from the provided origin in the provided direction.
A bounding volume specified as a longitude/latitude bounding box and a minimum and maximum height.
Classes that support manipulating the content of a glTF.
Hit result data for intersectRayGltfModel.
std::optional< RayGltfHit > hit
Optional hit result, if an intersection occurred.
Warnings encountered when traversing the glTF model.
Data describing a hit from a ray / gltf intersection test.
glm::dmat4x4 primitiveToWorld
Transformation from primitive to world space.
int32_t meshId
ID of the glTF mesh that was hit.
glm::dvec3 primitivePoint
Hit point in primitive space.
double rayToWorldPointDistanceSq
Square dist from intersection ray origin to world point.
glm::dvec3 worldPoint
Hit point in world space.
int32_t primitiveId
ID of the glTF primitive that was hit.
static std::vector< std::string_view > parseGltfCopyright(const std::string_view &s)
Parse a semicolon-separated string, such as the copyright field of a glTF model, and return the indiv...
static void compactBuffers(CesiumGltf::Model &gltf)
Shrink buffers by removing any sections that are not referenced by any BufferView.
static void removeUnusedSamplers(CesiumGltf::Model &gltf, const std::vector< int32_t > &extraUsedSamplerIndices={})
Removes unused samplers from the given glTF model.
static void removeUnusedBufferViews(CesiumGltf::Model &gltf, const std::vector< int32_t > &extraUsedBufferViewIndices={})
Removes unused buffer views from the given glTF model.
static glm::dmat4x4 applyRtcCenter(const CesiumGltf::Model &gltf, const glm::dmat4x4 &rootTransform)
Applies the glTF's RTC_CENTER, if any, to the given transform.
static IntersectResult intersectRayGltfModel(const CesiumGeometry::Ray &ray, const CesiumGltf::Model &gltf, bool cullBackFaces=true, const glm::dmat4x4 &gltfTransform=glm::dmat4(1.0))
Intersects a ray with a glTF model and returns the first intersection point.
static std::vector< std::string_view > parseGltfCopyright(const CesiumGltf::Model &gltf)
Parse the copyright field of a glTF model and return the individual credits.
static void setNodeTransform(CesiumGltf::Node &node, const glm::dmat4x4 &newTransform)
Sets the transformation matrix for a given node.
static void moveBufferContent(CesiumGltf::Model &gltf, CesiumGltf::Buffer &destination, CesiumGltf::Buffer &source)
Copies the content of one CesiumGltf::Buffer to the end of another, updates all CesiumGltf::BufferVie...
static void removeUnusedAccessors(CesiumGltf::Model &gltf, const std::vector< int32_t > &extraUsedAccessorIndices={})
Removes unused accessors from the given glTF model.
static void removeUnusedBuffers(CesiumGltf::Model &gltf, const std::vector< int32_t > &extraUsedBufferIndices={})
Removes unused buffers from the given glTF model.
static std::optional< glm::dmat4x4 > getNodeTransform(const CesiumGltf::Node &node)
Gets the transformation matrix for a given node.
static glm::dmat4x4 applyGltfUpAxisTransform(const CesiumGltf::Model &model, const glm::dmat4x4 &rootTransform)
Applies the glTF's gltfUpAxis, if any, to the given transform.
static CesiumGeospatial::BoundingRegion computeBoundingRegion(const CesiumGltf::Model &gltf, const glm::dmat4 &transform, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84)
Computes a bounding region from the vertex positions in a glTF model.
static void removeUnusedMaterials(CesiumGltf::Model &gltf, const std::vector< int32_t > &extraUsedMaterialIndices={})
Removes unused materials from the given glTF model.
static void removeUnusedImages(CesiumGltf::Model &gltf, const std::vector< int32_t > &extraUsedImageIndices={})
Removes unused images from the given glTF model.
static void setBoundingVolumeTransform(CesiumGltf::BoundingVolume &boundingVolume, const glm::dmat4x4 &newTransform)
Sets the transformation matrix for a given bounding volume.
static std::optional< glm::dmat4x4 > getBoundingVolumeTransform(const CesiumGltf::BoundingVolume &boundingVolume)
Gets the transformation matrix for a given bounding volume.
static void removeUnusedTextures(CesiumGltf::Model &gltf, const std::vector< int32_t > &extraUsedTextureIndices={})
Removes unused textures from the given glTF model.
static void collapseToSingleBuffer(CesiumGltf::Model &gltf)
Merges all of the glTF's buffers into a single buffer (the first one).
static void compactBuffer(CesiumGltf::Model &gltf, int32_t bufferIndex)
Shrink a buffer by removing any sections that are not referenced by any BufferView.
static void removeUnusedMeshes(CesiumGltf::Model &gltf, const std::vector< int32_t > &extraUsedMeshIndices={})
Removes unused meshes from the given glTF model.
A node in the node hierarchy. When the node contains skin, all mesh.primitives MUST contain JOINTS_0 ...
