Node.h
5#include <CesiumGltf/BoundingVolume.h>
7#include <CesiumGltf/NamedObject.h>
9#include <cstdint>
10#include <optional>
11#include <vector>
12
13namespace CesiumGltf {
25struct CESIUMGLTF_API Node final : public CesiumGltf::NamedObject {
29 static constexpr const char* TypeName = "Node";
30
34 std::optional<CesiumGltf::BoundingVolume> boundingVolume;
35
39 int32_t camera = -1;
40
44 std::vector<int32_t> children;
45
53 int32_t skin = -1;
54
59 std::vector<double> matrix = {1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1};
60
64 int32_t mesh = -1;
65
70 int32_t externalAsset = -1;
71
76 std::vector<double> rotation = {0, 0, 0, 1};
77
82 std::vector<double> scale = {1, 1, 1};
83
87 std::vector<double> translation = {0, 0, 0};
88
94 std::vector<double> weights;
95
102 int64_t getSizeBytes() const {
103 int64_t accum = 0;
104 accum += int64_t(sizeof(Node));
106 int64_t(sizeof(CesiumGltf::NamedObject));
107 if (this->boundingVolume) {
108 accum += this->boundingVolume->getSizeBytes() -
109 int64_t(sizeof(CesiumGltf::BoundingVolume));
110 }
111 accum += int64_t(sizeof(int32_t) * this->children.capacity());
112 accum += int64_t(sizeof(double) * this->matrix.capacity());
113 accum += int64_t(sizeof(double) * this->rotation.capacity());
114 accum += int64_t(sizeof(double) * this->scale.capacity());
115 accum += int64_t(sizeof(double) * this->translation.capacity());
116 accum += int64_t(sizeof(double) * this->weights.capacity());
117 return accum;
118 }
119};
120} // namespace CesiumGltf
Definition NamedObject.h:14
Definition NamedObject.h:28
A node in the node hierarchy. When the node contains skin, all mesh.primitives MUST contain JOINTS_0 ...
Definition Node.h:25
std::vector< double > matrix
A floating-point 4x4 transformation matrix stored in column-major order.
Definition Node.h:59
std::vector< double > translation
The node's translation along the x, y, and z axes.
Definition Node.h:87
std::vector< double > rotation
The node's unit quaternion rotation in the order (x, y, z, w), where w is the scalar.
Definition Node.h:76
std::vector< double > scale
The node's non-uniform scale, given as the scaling factors along the x, y, and z axes.
Definition Node.h:82
std::optional< CesiumGltf::BoundingVolume > boundingVolume
The bounding volume of the node.
Definition Node.h:34
std::vector< int32_t > children
The indices of this node's children.
Definition Node.h:44
std::vector< double > weights
The weights of the instantiated morph target. The number of array elements MUST match the number of m...
Definition Node.h:94
Definition Node.h:29
int32_t camera
The index of the camera referenced by this node.
Definition Node.h:39
int32_t skin
The index of the skin referenced by this node.
Definition Node.h:53
int32_t mesh
The index of the mesh in this node.
Definition Node.h:64
The index of the external asset in this node. Cannot be used together with mesh.
Definition Node.h:70
Definition Node.h:102
