BoundingVolume.h
3#include <Cesium3DTilesSelection/Library.h>
4#include <CesiumGeometry/BoundingCylinderRegion.h>
5#include <CesiumGeometry/BoundingSphere.h>
6#include <CesiumGeometry/OrientedBoundingBox.h>
7#include <CesiumGeospatial/BoundingRegion.h>
8#include <CesiumGeospatial/BoundingRegionWithLooseFittingHeights.h>
9#include <CesiumGeospatial/Ellipsoid.h>
10#include <CesiumGeospatial/GlobeRectangle.h>
11#include <CesiumGeospatial/S2CellBoundingVolume.h>
12
13#include <optional>
14#include <variant>
15
17
30typedef std::variant<
38
50CESIUM3DTILESSELECTION_API BoundingVolume transformBoundingVolume(
51 const glm::dmat4x4& transform,
52 const BoundingVolume& boundingVolume);
53
60CESIUM3DTILESSELECTION_API glm::dvec3
62
71CESIUM3DTILESSELECTION_API std::optional<CesiumGeospatial::GlobeRectangle>
73 const BoundingVolume& boundingVolume,
74 const CesiumGeospatial::Ellipsoid& ellipsoid CESIUM_DEFAULT_ELLIPSOID);
75
85CESIUM3DTILESSELECTION_API const CesiumGeospatial::BoundingRegion*
87
96CESIUM3DTILESSELECTION_API CesiumGeometry::OrientedBoundingBox
98 const BoundingVolume& boundingVolume,
99 const CesiumGeospatial::Ellipsoid& ellipsoid CESIUM_DEFAULT_ELLIPSOID);
100
104CESIUM3DTILESSELECTION_API bool
105testIntersection(const BoundingVolume& volume0, const BoundingVolume& volume1);
106} // namespace Cesium3DTilesSelection
A bounding volume defined as a region following the surface of a cylinder between two radius values....
A bounding sphere with a center and a radius.
A bounding volume defined as a closed and convex cuboid with any orientation.
A BoundingRegion whose heights might be very inaccurate and so distances should be estimated conserva...
A bounding volume specified as a longitude/latitude bounding box and a minimum and maximum height.
Definition Ellipsoid.h:39
CesiumGeometry::OrientedBoundingBox getOrientedBoundingBoxFromBoundingVolume(const BoundingVolume &boundingVolume, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84)
Returns an oriented bounding box that contains the given BoundingVolume.
std::variant< CesiumGeometry::BoundingSphere, CesiumGeometry::OrientedBoundingBox, CesiumGeospatial::BoundingRegion, CesiumGeospatial::BoundingRegionWithLooseFittingHeights, CesiumGeospatial::S2CellBoundingVolume, CesiumGeometry::BoundingCylinderRegion > BoundingVolume
A bounding volume.
bool testIntersection(const BoundingVolume &volume0, const BoundingVolume &volume1)
Returns true if two bounding volumes intersect.
const CesiumGeospatial::BoundingRegion * getBoundingRegionFromBoundingVolume(const BoundingVolume &boundingVolume)
Returns the bounding region if the bounding volume is a CesiumGeospatial::BoundingRegion or a CesiumG...
std::optional< CesiumGeospatial::GlobeRectangle > estimateGlobeRectangle(const BoundingVolume &boundingVolume, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84)
Estimates the bounding CesiumGeospatial::GlobeRectangle of the given BoundingVolume.
glm::dvec3 getBoundingVolumeCenter(const BoundingVolume &boundingVolume)
Returns the center of the given BoundingVolume.
BoundingVolume transformBoundingVolume(const glm::dmat4x4 &transform, const BoundingVolume &boundingVolume)
Transform the given BoundingVolume with the given matrix.
