Cesium for Unreal 2.31.0
Describes how a property from EXT_structural_metadata will be encoded for access in Unreal materials. More...
#include <CesiumMetadataEncodingDetails.h>
| FCesiumMetadataEncodingDetails () | |
| FCesiumMetadataEncodingDetails (ECesiumEncodedMetadataType InType, ECesiumEncodedMetadataComponentType InComponentType, ECesiumEncodedMetadataConversion InConversion) | |
| bool | operator== (const FCesiumMetadataEncodingDetails &Info) const |
| bool | operator!= (const FCesiumMetadataEncodingDetails &Info) const |
| bool | HasValidType () const |
| static FCesiumMetadataEncodingDetails | GetBestFitForProperty (const FCesiumMetadataPropertyDetails &PropertyDetails) |
| Gets the best-fitting encoded types and conversion method for a given metadata type. | |
| static TArray< ECesiumEncodedMetadataConversion > | GetSupportedConversionsForProperty (const FCesiumMetadataPropertyDetails &PropertyDetails) |
| Gets the possible conversion methods for a given metadata type. | |
| ECesiumEncodedMetadataType | Type |
| The GPU-compatible type that this property's values will be encoded as. | |
| ECesiumEncodedMetadataComponentType | ComponentType |
| The GPU-compatible component type that this property's values will be encoded as. | |
| ECesiumEncodedMetadataConversion | Conversion |
| The method of conversion used for this property. | |
Definition at line 84 of file CesiumMetadataEncodingDetails.h.
| FCesiumMetadataEncodingDetails::FCesiumMetadataEncodingDetails | ( | ) |
| FCesiumMetadataEncodingDetails::FCesiumMetadataEncodingDetails | ( | ECesiumEncodedMetadataType | InType, |
| ECesiumEncodedMetadataComponentType | InComponentType, | ||
| ECesiumEncodedMetadataConversion | InConversion ) |
static |
This determines the best way (if one is possible) to transfer values of the given type to the GPU, for access in Unreal materials.
An array size can also be supplied if bIsArray is true on the given value type. If bIsArray is true, but the given array size is zero, this indicates the arrays of the property vary in length. Variable-length array properties are unsupported.
| PropertyDetails | The metadata property details |
static |
Returns an empty array if no conversions are possible.
| bool FCesiumMetadataEncodingDetails::HasValidType | ( | ) | const |
| bool FCesiumMetadataEncodingDetails::operator!= | ( | const FCesiumMetadataEncodingDetails & | Info | ) | const |
| bool FCesiumMetadataEncodingDetails::operator== | ( | const FCesiumMetadataEncodingDetails & | Info | ) | const |
| ECesiumEncodedMetadataComponentType FCesiumMetadataEncodingDetails::ComponentType |
These correspond to the pixel component types that are supported in Unreal textures.
Definition at line 106 of file CesiumMetadataEncodingDetails.h.
| ECesiumEncodedMetadataConversion FCesiumMetadataEncodingDetails::Conversion |
This describes how the values will be converted for access in Unreal materials. Note that not all property types are compatible with the methods of conversion.
Definition at line 114 of file CesiumMetadataEncodingDetails.h.
| ECesiumEncodedMetadataType FCesiumMetadataEncodingDetails::Type |
Definition at line 98 of file CesiumMetadataEncodingDetails.h.
