Cesium for Unreal
2.31.0
CesiumMetadataEncodingDetails.h
1
// Copyright 2020-2026 CesiumGS, Inc. and Contributors
3
#pragma once
5
#include "
CesiumMetadataValueType.h
6
#include <cstdlib>
#include <type_traits>
9
#include "CesiumMetadataEncodingDetails.generated.h"
10
11
struct
FCesiumMetadataPropertyDetails
12
13
14
* @brief The component type that a metadata property's values will be encoded
15
* as. These correspond to the pixel component types that are supported in
16
* Unreal textures.
17
18
UENUM()
19
enum class
ECesiumEncodedMetadataComponentType
: uint8 {
None
Uint8
Float
20
21
22
* @brief Gets the best-fitting encoded type for the given metadata component
23
* type.
24
25
26
CesiumMetadataComponentTypeToEncodingType
ECesiumMetadataComponentType
Type
27
28
29
* @brief The type that a metadata property's values will be encoded as.
30
31
UENUM()
32
enum class
ECesiumEncodedMetadataType
: uint8 {
33
None
34
Scalar
35
Vec2
36
Vec3
37
Vec4
38
39
40
41
* @brief Gets the best-fitting encoded type for the given metadata type.
42
43
44
CesiumMetadataTypeToEncodingType
ECesiumMetadataType
Type
45
46
47
* @brief Gets the number of components associated with the given encoded type.
48
* @param type The encoded metadata type.
49
50
size_t
51
CesiumGetEncodedMetadataTypeComponentCount
Type
52
53
54
* @brief Indicates how a property value from EXT_structural_metadata should be
55
* converted to a GPU-accessible type, if possible.
56
57
UENUM()
58
enum class
ECesiumEncodedMetadataConversion
: uint8 {
59
60
* Do nothing. This is typically used for property types that are
61
* completely unable to be coerced.
62
63
None
64
65
* Coerce the components of a property value to the specified component type.
66
* If the property contains string values, this attempts to parse numbers from
67
* the strings as uint8s.
68
69
Coerce
70
71
* Attempt to parse a color from a string property value. This supports
72
* the following formats:
73
* - `rgb(R, G, B)`, where R, G, and B are values in the range [0, 255]
74
* - hexcode colors, e.g. `#ff0000`
75
76
ParseColorFromString
77
78
79
80
* Describes how a property from EXT_structural_metadata will be encoded for
81
* access in Unreal materials.
82
83
USTRUCT
84
struct CESIUMRUNTIME_API
FCesiumMetadataEncodingDetails
85
GENERATED_USTRUCT_BODY()
86
87
88
89
90
InType,
91
InComponentType,
92
InConversion);
93
94
95
* The GPU-compatible type that this property's values will be encoded as.
96
97
UPROPERTY(EditAnywhere, Category =
"Cesium"
98
Type
99
100
101
* The GPU-compatible component type that this property's values will be
102
* encoded as. These correspond to the pixel component types that are
103
* supported in Unreal textures.
104
105
"Cesium"
106
ComponentType
107
108
109
* The method of conversion used for this property. This describes how the
110
* values will be converted for access in Unreal materials. Note that not all
111
* property types are compatible with the methods of conversion.
112
113
"Cesium"
114
Conversion
115
116
bool
operator==(const
& Info) const;
117
118
bool
operator!=(const
& Info) const;
119
120
bool
HasValidType
() const;
121
122
123
* @brief Gets the best-fitting encoded types and conversion method for a
124
* given metadata type. This determines the best way (if one is possible) to
125
* transfer values of the given type to the GPU, for access in Unreal
126
* materials.
127
128
* An array size can also be supplied if bIsArray is true on the given value
129
* type. If bIsArray is true, but the given array size is zero, this indicates
130
* the arrays of the property vary in length. Variable-length array properties
131
* are unsupported.
132
133
* @param PropertyDetails The metadata property details
134
135
static
136
GetBestFitForProperty
(const
& PropertyDetails);
137
138
139
* @brief Gets the possible conversion methods for a given metadata type.
140
* Returns an empty array if no conversions are possible.
141
142
143
144
static TArray<
145
GetSupportedConversionsForProperty
146
const
& PropertyDetails);
147
ECesiumFeatureIdSetType::None
@ None
Definition
CesiumFeatureIdSet.h:22
Indicates how a property value from EXT_structural_metadata should be converted to a GPU-accessible t...
Definition
CesiumMetadataEncodingDetails.h:58
ECesiumEncodedMetadataConversion::ParseColorFromString
@ ParseColorFromString
Definition
CesiumMetadataEncodingDetails.h:76
ECesiumEncodedMetadataConversion::Coerce
@ Coerce
Definition
CesiumMetadataEncodingDetails.h:69
ECesiumEncodedMetadataComponentType CesiumMetadataComponentTypeToEncodingType(ECesiumMetadataComponentType Type)
Gets the best-fitting encoded type for the given metadata component type.
Definition
CesiumMetadataEncodingDetails.h:32
ECesiumEncodedMetadataType::Vec3
@ Vec3
Definition
CesiumMetadataEncodingDetails.h:36
ECesiumEncodedMetadataType::Scalar
@ Scalar
Definition
CesiumMetadataEncodingDetails.h:34
ECesiumEncodedMetadataType::Vec4
@ Vec4
Definition
CesiumMetadataEncodingDetails.h:37
ECesiumEncodedMetadataType::Vec2
@ Vec2
Definition
CesiumMetadataEncodingDetails.h:35
size_t CesiumGetEncodedMetadataTypeComponentCount(ECesiumEncodedMetadataType Type)
ECesiumEncodedMetadataType CesiumMetadataTypeToEncodingType(ECesiumMetadataType Type)
The component type that a metadata property's values will be encoded as.
Definition
CesiumMetadataEncodingDetails.h:19
ECesiumEncodedMetadataComponentType::Float
@ Float
Definition
ECesiumEncodedMetadataComponentType::Uint8
@ Uint8
Definition
The component type of a metadata property in EXT_structural_metadata.
Definition
CesiumMetadataValueType.h:125
ECesiumMetadataType
ECesiumMetadataType
The type of a metadata property in EXT_structural_metadata.
Definition
CesiumMetadataValueType.h:106
USTRUCT
Definition
CesiumVoxelMetadataComponent.h:22
FCesiumMetadataEncodingDetails::GetBestFitForProperty
static FCesiumMetadataEncodingDetails GetBestFitForProperty(const FCesiumMetadataPropertyDetails &PropertyDetails)
Gets the best-fitting encoded types and conversion method for a given metadata type.
FCesiumMetadataEncodingDetails::FCesiumMetadataEncodingDetails
FCesiumMetadataEncodingDetails()
FCesiumMetadataEncodingDetails::GetSupportedConversionsForProperty
static TArray< ECesiumEncodedMetadataConversion > GetSupportedConversionsForProperty(const FCesiumMetadataPropertyDetails &PropertyDetails)
FCesiumMetadataEncodingDetails::Conversion
ECesiumEncodedMetadataConversion Conversion
Definition
CesiumMetadataEncodingDetails.h:114
FCesiumMetadataEncodingDetails::HasValidType
bool HasValidType() const
FCesiumMetadataEncodingDetails::ComponentType
ECesiumEncodedMetadataComponentType ComponentType
The GPU-compatible component type that this property's values will be encoded as.
Definition
CesiumMetadataEncodingDetails.h:106
FCesiumMetadataEncodingDetails::Type
Definition
CesiumMetadataEncodingDetails.h:98
Represents information about a metadata property according to how the property is defined in EXT_stru...
Definition
CesiumMetadataPropertyDetails.h:15
FCesiumMetadataPropertyDetails::Type
The type of the metadata property.
Definition
CesiumMetadataPropertyDetails.h:33
Source
CesiumRuntime
Public
Generated by
1.13.2
