FCesiumPropertyTablePropertyDescription Struct Reference
Description of a property table property that should be encoded for access on the GPU. More...
#include <CesiumFeaturesMetadataDescription.h>
FString Name
 The name of this property.
FCesiumMetadataPropertyDetails PropertyDetails
 Describes the underlying type of this property and other relevant information from its EXT_structural_metadata definition.
FCesiumMetadataEncodingDetails EncodingDetails
 Describes how the property will be encoded as data on the GPU, if possible.
Definition at line 141 of file CesiumFeaturesMetadataDescription.h.
◆ EncodingDetails
FCesiumMetadataEncodingDetails FCesiumPropertyTablePropertyDescription::EncodingDetails
Definition at line 163 of file CesiumFeaturesMetadataDescription.h.
◆ Name
FString FCesiumPropertyTablePropertyDescription::Name
This will be how it is referenced in the material.
Definition at line 149 of file CesiumFeaturesMetadataDescription.h.
◆ PropertyDetails
FCesiumMetadataPropertyDetails FCesiumPropertyTablePropertyDescription::PropertyDetails
Not all types of properties can be encoded to the GPU, or coerced to GPU-compatible types.
Definition at line 157 of file CesiumFeaturesMetadataDescription.h.
