CesiumMetadataEncodingDetails.h File Reference
#include "CesiumMetadataValueType.h"
#include <cstdlib>
#include <type_traits>
#include "CesiumMetadataEncodingDetails.generated.h"
Classes
struct  FCesiumMetadataEncodingDetails
 Describes how a property from EXT_structural_metadata will be encoded for access in Unreal materials. More...
Enumerations
enum class  ECesiumEncodedMetadataComponentType : uint8 { None , Uint8 , Float }
 The component type that a metadata property's values will be encoded as. More...
enum class  ECesiumEncodedMetadataType : uint8 {
  None , Scalar , Vec2 , Vec3 ,
  Vec4
 The type that a metadata property's values will be encoded as. More...
enum class  ECesiumEncodedMetadataConversion : uint8 { None , Coerce , ParseColorFromString }
 Indicates how a property value from EXT_structural_metadata should be converted to a GPU-accessible type, if possible. More...
Functions
ECesiumEncodedMetadataComponentType CesiumMetadataComponentTypeToEncodingType (ECesiumMetadataComponentType Type)
 Gets the best-fitting encoded type for the given metadata component type.
ECesiumEncodedMetadataType CesiumMetadataTypeToEncodingType (ECesiumMetadataType Type)
 Gets the best-fitting encoded type for the given metadata type.
size_t CesiumGetEncodedMetadataTypeComponentCount (ECesiumEncodedMetadataType Type)
 Gets the number of components associated with the given encoded type.
◆ ECesiumEncodedMetadataComponentType
strong
These correspond to the pixel component types that are supported in Unreal textures.
Enumerator
None
Uint8
Float
Definition at line 19 of file CesiumMetadataEncodingDetails.h.
◆ ECesiumEncodedMetadataConversion
strong
Enumerator
None
Do nothing.
This is typically used for property types that are completely unable to be coerced.
Coerce
Coerce the components of a property value to the specified component type.
If the property contains string values, this attempts to parse numbers from the strings as uint8s.
Attempt to parse a color from a string property value.
This supports the following formats:
  • rgb(R, G, B), where R, G, and B are values in the range [0, 255]
  • hexcode colors, e.g. #ff0000
Definition at line 58 of file CesiumMetadataEncodingDetails.h.
◆ ECesiumEncodedMetadataType
strong
Enumerator
None
Scalar
Vec2
Vec3
Vec4
Definition at line 32 of file CesiumMetadataEncodingDetails.h.
Function Documentation
◆ CesiumGetEncodedMetadataTypeComponentCount()
size_t CesiumGetEncodedMetadataTypeComponentCount ( ECesiumEncodedMetadataType Type)
typeThe encoded metadata type.
◆ CesiumMetadataComponentTypeToEncodingType()
ECesiumEncodedMetadataComponentType CesiumMetadataComponentTypeToEncodingType ( ECesiumMetadataComponentType Type)
◆ CesiumMetadataTypeToEncodingType()
ECesiumEncodedMetadataType CesiumMetadataTypeToEncodingType ( ECesiumMetadataType Type)
