FCesiumFeatureIdSetDescription Struct Reference
Description of a feature ID set from either EXT_mesh_features or EXT_instance_features. More...
#include <CesiumFeaturesMetadataDescription.h>
FString Name
 The display name of the feature ID set.
ECesiumFeatureIdSetType Type = ECesiumFeatureIdSetType::None
 The type of the feature ID set.
FString PropertyTableName
 The name of the property table that this feature ID set corresponds to.
ECesiumFeatureStylingMode StylingMode = ECesiumFeatureStylingMode::Material
 The method used to apply styling to individual features.
Definition at line 48 of file CesiumFeaturesMetadataDescription.h.
◆ Name
FString FCesiumFeatureIdSetDescription::Name
If the feature ID set already has a label, this will use the label. Otherwise, if the feature ID set is unlabeled, a name will be generated like so:
  • If the feature ID set is an attribute, this will appear as "_FEATURE_ID_\<index\>", where <index> is the set index specified in the attribute.
  • If the feature ID set is a texture, this will appear as "_FEATURE_ID_TEXTURE_\<index\>", where <index> increments with the number of feature ID textures seen in an individual primitive.
  • If the feature ID set is an implicit set, this will appear as "_IMPLICIT_FEATURE_ID". Implicit feature ID sets don't vary in definition, so any additional implicit feature ID sets across the primitives are counted by this one.
This name will also be used to represent the feature ID set in the generated material.
Definition at line 71 of file CesiumFeaturesMetadataDescription.h.
◆ PropertyTableName
FString FCesiumFeatureIdSetDescription::PropertyTableName
Definition at line 83 of file CesiumFeaturesMetadataDescription.h.
◆ StylingMode
ECesiumFeatureStylingMode FCesiumFeatureIdSetDescription::StylingMode = ECesiumFeatureStylingMode::Material
By default, metadata properties are encoded to textures and passed the generated material, allowing use with material logic. However, they can also be styled in a prepass using Blueprints.
Definition at line 93 of file CesiumFeaturesMetadataDescription.h.
◆ Type
ECesiumFeatureIdSetType FCesiumFeatureIdSetDescription::Type = ECesiumFeatureIdSetType::None
Definition at line 77 of file CesiumFeaturesMetadataDescription.h.
