Cesium for Unreal 2.31.0
Represents information about a metadata property according to how the property is defined in EXT_structural_metadata. More...
#include <CesiumMetadataPropertyDetails.h>
| FCesiumMetadataPropertyDetails () | |
| FCesiumMetadataPropertyDetails (ECesiumMetadataType InType, ECesiumMetadataComponentType InComponentType, bool IsArray) | |
| bool | operator== (const FCesiumMetadataPropertyDetails &ValueType) const |
| bool | operator!= (const FCesiumMetadataPropertyDetails &ValueType) const |
| FCesiumMetadataValueType | GetValueType () const |
| Returns the internal types as a FCesiumMetadataValueType. | |
| void | SetValueType (FCesiumMetadataValueType ValueType) |
| Sets the internal types to the values supplied by the input FCesiumMetadataValueType. | |
| bool | HasValueTransforms () const |
| Whether this property has one or more value transforms. | |
| ECesiumMetadataType | Type = ECesiumMetadataType::Invalid |
| The type of the metadata property. | |
| ECesiumMetadataComponentType | ComponentType |
| The component of the metadata property. | |
| bool | bIsArray = false |
| Whether or not this represents an array containing elements of the specified types. | |
| int64 | ArraySize = 0 |
| The size of the arrays in the metadata property. | |
| bool | bIsNormalized = false |
| Whether or not the values in this property are normalized. | |
| bool | bHasOffset = false |
| Whether or not the property is transformed by an offset. | |
| bool | bHasScale = false |
| Whether or not the property is transformed by a scale. | |
| bool | bHasNoDataValue = false |
| Whether or not the property specifies a "no data" value. | |
| bool | bHasDefaultValue = false |
| Whether or not the property specifies a default value. | |
Definition at line 15 of file CesiumMetadataPropertyDetails.h.
Definition at line 18 of file CesiumMetadataPropertyDetails.h.
Definition at line 23 of file CesiumMetadataPropertyDetails.h.
Definition at line 147 of file CesiumMetadataPropertyDetails.h.
This includes normalization, offset, and scale, as well as the "no data" and default values.
Definition at line 166 of file CesiumMetadataPropertyDetails.h.
Definition at line 140 of file CesiumMetadataPropertyDetails.h.
Definition at line 134 of file CesiumMetadataPropertyDetails.h.
Definition at line 155 of file CesiumMetadataPropertyDetails.h.
| int64 FCesiumMetadataPropertyDetails::ArraySize = 0 |
If the property contains arrays of varying length, this will be zero even though bIsArray will be true> If this property does not contain arrays, this is set to zero.
Definition at line 64 of file CesiumMetadataPropertyDetails.h.
| bool FCesiumMetadataPropertyDetails::bHasDefaultValue = false |
This default value is used use when encountering a "no data" value in the property, or when a non-required property has been omitted.
Definition at line 131 of file CesiumMetadataPropertyDetails.h.
| bool FCesiumMetadataPropertyDetails::bHasNoDataValue = false |
This value functions a sentinel value, indicating missing data wherever it appears.
Definition at line 118 of file CesiumMetadataPropertyDetails.h.
| bool FCesiumMetadataPropertyDetails::bHasOffset = false |
This value is defined either in the class property, or in the instance of the property itself.
Definition at line 93 of file CesiumMetadataPropertyDetails.h.
| bool FCesiumMetadataPropertyDetails::bHasScale = false |
Definition at line 106 of file CesiumMetadataPropertyDetails.h.
| bool FCesiumMetadataPropertyDetails::bIsArray = false |
Definition at line 53 of file CesiumMetadataPropertyDetails.h.
| bool FCesiumMetadataPropertyDetails::bIsNormalized = false |
Only applicable to scalar, vecN, and matN types with integer components.
For unsigned integer component types, values are normalized between [0.0, 1.0]. For signed integer component types, values are normalized between [-1.0, 1.0]
Definition at line 80 of file CesiumMetadataPropertyDetails.h.
| ECesiumMetadataComponentType FCesiumMetadataPropertyDetails::ComponentType |
Only applies when the type is a Scalar, VecN, or MatN type.
Definition at line 45 of file CesiumMetadataPropertyDetails.h.
| ECesiumMetadataType FCesiumMetadataPropertyDetails::Type = ECesiumMetadataType::Invalid |
Definition at line 33 of file CesiumMetadataPropertyDetails.h.
