CesiumGltf::Shape Struct Referencefinal
A generic, re-usable shape definition with no inherent meaning attached to it. More...
#include <CesiumGltf/Shape.h>
Inheritance diagram for CesiumGltf::Shape:
Classes
struct  Type
 Known values for The type of shape this shape object represents. If any properties are explicitly specified for the shape, the shape properties object MUST match the shape type. More...
std::string type = Type::box
std::optional< CesiumGltf::Box > box
 Parameter values defining a box shape.
std::optional< CesiumGltf::Capsule > capsule
 Parameter values defining a capsule shape.
std::optional< CesiumGltf::Cylinder > cylinder
 Parameter values defining a cylinder shape.
std::optional< CesiumGltf::Plane > plane
 Parameter values defining a plane shape.
std::optional< CesiumGltf::Sphere > sphere
 Parameter values defining a sphere shape.
std::string name
static constexpr const char * TypeName = "Shape"
Definition at line 21 of file Shape.h.
int64_t CesiumGltf::Shape::getSizeBytes ( ) const
Definition at line 90 of file Shape.h.
◆ box
std::optional<CesiumGltf::Box> CesiumGltf::Shape::box
Definition at line 62 of file Shape.h.
◆ capsule
std::optional<CesiumGltf::Capsule> CesiumGltf::Shape::capsule
Definition at line 67 of file Shape.h.
◆ cylinder
std::optional<CesiumGltf::Cylinder> CesiumGltf::Shape::cylinder
Definition at line 72 of file Shape.h.
◆ plane
std::optional<CesiumGltf::Plane> CesiumGltf::Shape::plane
Definition at line 77 of file Shape.h.
◆ sphere
std::optional<CesiumGltf::Sphere> CesiumGltf::Shape::sphere
Definition at line 82 of file Shape.h.
◆ type
std::string CesiumGltf::Shape::type = Type::box
Definition at line 57 of file Shape.h.
const char* CesiumGltf::Shape::TypeName = "Shape"
Definition at line 25 of file Shape.h.
