CesiumGltf::Box Struct Referencefinal
An axis-aligned box with a size per-axis, centered at the origin in local space, with normals facing outwards along each axis. More...
#include <CesiumGltf/Box.h>
Inheritance diagram for CesiumGltf::Box:
std::vector< double > size = {1, 1, 1}
 The size of the box in each axis in local space.
static constexpr const char * TypeName = "Box"
Definition at line 15 of file Box.h.
int64_t CesiumGltf::Box::getSizeBytes ( ) const
Definition at line 32 of file Box.h.
◆ size
std::vector<double> CesiumGltf::Box::size = {1, 1, 1}
Definition at line 24 of file Box.h.
const char* CesiumGltf::Box::TypeName = "Box"
Definition at line 19 of file Box.h.
