CesiumGltf::Capsule Struct Referencefinal
A capsule, centered at the origin in local space with potentially different radii at each end, equivalent to the convex hull of two spheres located along the Y axis (in local space) at a specified distance, with normals facing outwards. More...
#include <CesiumGltf/Capsule.h>
Inheritance diagram for CesiumGltf::Capsule:
double height = 1
 The distance between the centers of the two capping spheres of capsule, also known as the mid-height.
double radiusBottom = 0.5
 The radius of the sphere located at the bottom of the capsule (i.e. the sphere at the half-height along -Y)
double radiusTop = 0.5
 The radius of the sphere located at the top of the capsule (i.e. the sphere at the half-height along +Y)
static constexpr const char * TypeName = "Capsule"
Definition at line 15 of file Capsule.h.
int64_t CesiumGltf::Capsule::getSizeBytes ( ) const
Definition at line 45 of file Capsule.h.
◆ height
double CesiumGltf::Capsule::height = 1
Definition at line 25 of file Capsule.h.
◆ radiusBottom
double CesiumGltf::Capsule::radiusBottom = 0.5
Definition at line 31 of file Capsule.h.
◆ radiusTop
double CesiumGltf::Capsule::radiusTop = 0.5
Definition at line 37 of file Capsule.h.
const char* CesiumGltf::Capsule::TypeName = "Capsule"
Definition at line 19 of file Capsule.h.
