A plane centered at the origin in local space, optionally with finite extents, with normal along the +Y axis in local space. The plane is one-sided.
More...
#include <CesiumGltf/Plane.h>
| | Calculates the size in bytes of this object, including the contents of all collections, pointers, and strings. This will NOT include the size of any extensions attached to the object. Calling this method may be slow as it requires traversing the object's entire structure.
| template<typename T> |
| | Checks if an extension exists given its static type.
| | Gets an extension given its static type.
| | Gets a generic extension with the given name as a CesiumUtility::JsonValue.
| template<typename T, typename... ConstructorArgumentTypes> |
| | Adds a statically-typed extension to this object.
| | Removes a statically-typed extension from this object.
| | Calculates the size in bytes of this ExtensibleObject, including all of its extras but NOT including its extensions. Calling this method may be slow as it requires traversing the entire object.
| std::optional< double > | sizeX |
| | The extents along the X axis in local space. If not provided, this dimension should be considered infinite.
| std::optional< double > | sizeZ |
| | The extents along the Z axis in local space. If not provided, this dimension should be considered infinite.
| | The extensions attached to this object.
| | Application-specific data.
| | Unknown properties that exist on this object but do not have any representation in the statically-typed classes.
| static constexpr const char * | TypeName = "Plane" |
| | The original name of this type.
Definition at line 16 of file Plane.h.
◆ getSizeBytes()
| int64_t CesiumGltf::Plane::getSizeBytes |
const |
Definition at line 40 of file Plane.h.
◆ sizeX
| std::optional<double> CesiumGltf::Plane::sizeX |
Definition at line 26 of file Plane.h.
◆ sizeZ
| std::optional<double> CesiumGltf::Plane::sizeZ |
Definition at line 32 of file Plane.h.
◆ TypeName
| const char* CesiumGltf::Plane::TypeName = "Plane" |
Definition at line 20 of file Plane.h.
- /home/runner/work/cesium-native/cesium-native/CesiumGltf/generated/include/CesiumGltf/Plane.h
