A cylinder, centered at the origin in local space with potentially different radii at each end, equivalent to the convex hull of two circles in the X/Z plane positioned along the Y axis at a specified distance, with the top cap normal facing along the +Y axis, the bottom cap normal facing along the -Y axis, and the side normals facing outwards along the X/Z plane. More...
#include <CesiumGltf/Cylinder.h>
| double | height = 2 |
| The height of the cylinder, centered along the Y axis. | |
| double | radiusBottom = 0.5 |
| The radius of the bottom of the cylinder (the disc located along -Y.) | |
| double | radiusTop = 0.5 |
| The radius of the top of the cylinder (the disc located along +Y.) | |
| static constexpr const char * | TypeName = "Cylinder" |
Definition at line 16 of file Cylinder.h.
Definition at line 44 of file Cylinder.h.
| double CesiumGltf::Cylinder::height = 2 |
Definition at line 25 of file Cylinder.h.
| double CesiumGltf::Cylinder::radiusBottom = 0.5 |
Definition at line 31 of file Cylinder.h.
| double CesiumGltf::Cylinder::radiusTop = 0.5 |
Definition at line 36 of file Cylinder.h.
Definition at line 20 of file Cylinder.h.
