Material Normal Texture Info. More...
#include <CesiumGltf/MaterialNormalTextureInfo.h>
Public Member Functions inherited from CesiumGltf::TextureInfo | |
| double | scale = 1 |
| The scalar parameter applied to each normal vector of the normal texture. | |
Public Attributes inherited from CesiumGltf::TextureInfo | |
| int32_t | index = -1 |
| The index of the texture. | |
| int64_t | texCoord = 0 |
| The set index of texture's TEXCOORD attribute used for texture coordinate mapping. | |
| static constexpr const char * | TypeName = "MaterialNormalTextureInfo" |
Static Public Attributes inherited from CesiumGltf::TextureInfo | |
| static constexpr const char * | TypeName = "TextureInfo" |
Definition at line 12 of file MaterialNormalTextureInfo.h.
Definition at line 35 of file MaterialNormalTextureInfo.h.
| double CesiumGltf::MaterialNormalTextureInfo::scale = 1 |
The scalar parameter applied to each normal vector of the texture. This value scales the normal vector in X and Y directions using the formula: scaledNormal = normalize((<sampled normal texture value> * 2.0 - 1.0) * vec3(<normal scale>, <normal scale>, 1.0)).
Definition at line 27 of file MaterialNormalTextureInfo.h.
Definition at line 16 of file MaterialNormalTextureInfo.h.
