CesiumGltf::MaterialPBRMetallicRoughness Struct Referencefinal
A set of parameter values that are used to define the metallic-roughness material model from Physically-Based Rendering (PBR) methodology. More...
#include <CesiumGltf/MaterialPBRMetallicRoughness.h>
Inheritance diagram for CesiumGltf::MaterialPBRMetallicRoughness:
std::vector< double > baseColorFactor = {1, 1, 1, 1}
 The factors for the base color of the material.
std::optional< CesiumGltf::TextureInfo > baseColorTexture
 The base color texture.
double metallicFactor = 1
 The factor for the metalness of the material.
double roughnessFactor = 1
 The factor for the roughness of the material.
std::optional< CesiumGltf::TextureInfo > metallicRoughnessTexture
 The metallic-roughness texture.
static constexpr const char * TypeName = "MaterialPBRMetallicRoughness"
Definition at line 18 of file MaterialPBRMetallicRoughness.h.
int64_t CesiumGltf::MaterialPBRMetallicRoughness::getSizeBytes ( ) const
Definition at line 79 of file MaterialPBRMetallicRoughness.h.
◆ baseColorFactor
std::vector<double> CesiumGltf::MaterialPBRMetallicRoughness::baseColorFactor = {1, 1, 1, 1}
This value defines linear multipliers for the sampled texels of the base color texture.
Definition at line 31 of file MaterialPBRMetallicRoughness.h.
◆ baseColorTexture
std::optional<CesiumGltf::TextureInfo> CesiumGltf::MaterialPBRMetallicRoughness::baseColorTexture
The first three components (RGB) MUST be encoded with the sRGB transfer function. They specify the base color of the material. If the fourth component (A) is present, it represents the linear alpha coverage of the material. Otherwise, the alpha coverage is equal to 1.0. The material.alphaMode property specifies how alpha is interpreted. The stored texels MUST NOT be premultiplied. When undefined, the texture MUST be sampled as having 1.0 in all components.
Definition at line 44 of file MaterialPBRMetallicRoughness.h.
◆ metallicFactor
double CesiumGltf::MaterialPBRMetallicRoughness::metallicFactor = 1
This value defines a linear multiplier for the sampled metalness values of the metallic-roughness texture.
Definition at line 52 of file MaterialPBRMetallicRoughness.h.
◆ metallicRoughnessTexture
std::optional<CesiumGltf::TextureInfo> CesiumGltf::MaterialPBRMetallicRoughness::metallicRoughnessTexture
The metalness values are sampled from the B channel. The roughness values are sampled from the G channel. These values MUST be encoded with a linear transfer function. If other channels are present (R or A), they MUST be ignored for metallic-roughness calculations. When undefined, the texture MUST be sampled as having 1.0 in G and B components.
Definition at line 71 of file MaterialPBRMetallicRoughness.h.
◆ roughnessFactor
double CesiumGltf::MaterialPBRMetallicRoughness::roughnessFactor = 1
This value defines a linear multiplier for the sampled roughness values of the metallic-roughness texture.
Definition at line 60 of file MaterialPBRMetallicRoughness.h.
const char* CesiumGltf::MaterialPBRMetallicRoughness::TypeName = "MaterialPBRMetallicRoughness"
Definition at line 23 of file MaterialPBRMetallicRoughness.h.
