Material Occlusion Texture Info. More...
#include <CesiumGltf/MaterialOcclusionTextureInfo.h>
Public Member Functions inherited from CesiumGltf::TextureInfo | |
| double | strength = 1 |
| A scalar multiplier controlling the amount of occlusion applied. | |
Public Attributes inherited from CesiumGltf::TextureInfo | |
| int32_t | index = -1 |
| The index of the texture. | |
| int64_t | texCoord = 0 |
| The set index of texture's TEXCOORD attribute used for texture coordinate mapping. | |
| static constexpr const char * | TypeName = "MaterialOcclusionTextureInfo" |
Static Public Attributes inherited from CesiumGltf::TextureInfo | |
| static constexpr const char * | TypeName = "TextureInfo" |
Definition at line 12 of file MaterialOcclusionTextureInfo.h.
Definition at line 34 of file MaterialOcclusionTextureInfo.h.
| double CesiumGltf::MaterialOcclusionTextureInfo::strength = 1 |
A scalar parameter controlling the amount of occlusion applied. A value of 0.0 means no occlusion. A value of 1.0 means full occlusion. This value affects the final occlusion value as: 1.0 + strength * (<sampled occlusion texture value> - 1.0).
Definition at line 26 of file MaterialOcclusionTextureInfo.h.
Definition at line 16 of file MaterialOcclusionTextureInfo.h.
