AccessorSpec.h
5#include <CesiumGltf/AccessorSparse.h>
7#include <CesiumGltf/NamedObject.h>
9#include <cstdint>
10#include <optional>
11#include <string>
12#include <vector>
13
14namespace CesiumGltf {
18struct CESIUMGLTF_API AccessorSpec : public CesiumGltf::NamedObject {
22 static constexpr const char* TypeName = "Accessor";
23
29 static constexpr int32_t BYTE = 5120;
30
32 static constexpr int32_t UNSIGNED_BYTE = 5121;
33
35 static constexpr int32_t SHORT = 5122;
36
38 static constexpr int32_t UNSIGNED_SHORT = 5123;
39
41 static constexpr int32_t INT = 5124;
42
44 static constexpr int32_t UNSIGNED_INT = 5125;
45
47 static constexpr int32_t INT64 = 5134;
48
50 static constexpr int32_t UNSIGNED_INT64 = 5135;
51
53 static constexpr int32_t FLOAT = 5126;
54
56 static constexpr int32_t DOUBLE = 5130;
57 };
58
63 struct Type {
65 inline static const std::string SCALAR = "SCALAR";
66
68 inline static const std::string VEC2 = "VEC2";
69
71 inline static const std::string VEC3 = "VEC3";
72
74 inline static const std::string VEC4 = "VEC4";
75
77 inline static const std::string MAT2 = "MAT2";
78
80 inline static const std::string MAT3 = "MAT3";
81
83 inline static const std::string MAT4 = "MAT4";
84 };
85
93 int32_t bufferView = -1;
94
101 int64_t byteOffset = 0;
102
113
122 bool normalized = false;
123
130 int64_t count = int64_t();
131
139 std::string type = Type::SCALAR;
140
154 std::vector<double> max;
155
169 std::vector<double> min;
170
175 std::optional<CesiumGltf::AccessorSparse> sparse;
176
183 int64_t getSizeBytes() const {
184 int64_t accum = 0;
185 accum += int64_t(sizeof(AccessorSpec));
187 int64_t(sizeof(CesiumGltf::NamedObject));
188 accum += int64_t(sizeof(double) * this->max.capacity());
189 accum += int64_t(sizeof(double) * this->min.capacity());
190 if (this->sparse) {
191 accum += this->sparse->getSizeBytes() -
192 int64_t(sizeof(CesiumGltf::AccessorSparse));
193 }
194 return accum;
195 }
196
197protected:
202 AccessorSpec() = default;
203 friend struct Accessor;
204};
205} // namespace CesiumGltf
Sparse storage of accessor values that deviate from their initialization value.
Known values for The datatype of the accessor's components.
DOUBLE (5130)
INT (5124)
UNSIGNED_SHORT (5123)
UNSIGNED_INT (5125)
UNSIGNED_BYTE (5121)
SHORT (5122)
UNSIGNED_INT64 (5135)
INT64 (5134)
BYTE (5120)
FLOAT (5126)
Known values for Specifies if the accessor's elements are scalars, vectors, or matrices.
SCALAR
VEC4
MAT4
VEC3
MAT3
VEC2
MAT2
int64_t byteOffset
The offset relative to the start of the buffer view in bytes.
std::optional< CesiumGltf::AccessorSparse > sparse
Sparse storage of elements that deviate from their initialization value.
bool normalized
Specifies whether integer data values are normalized before usage.
AccessorSpec()=default
This class is not meant to be instantiated directly. Use Accessor instead.
std::string type
std::vector< double > min
Minimum value of each component in this accessor.
int64_t count
The number of elements referenced by this accessor.
int32_t componentType
std::vector< double > max
Maximum value of each component in this accessor.
int32_t bufferView
The index of the bufferView.
Definition NamedObject.h:14
Definition NamedObject.h:28
