Rendering 3D Tiles
One of the main reasons to integrate Cesium Native into an application is to add support for rendering 3D Tiles. This guide explains how that can be done.
A 3D Tiles Tileset is a potentially massive 3D model - such as the entire Earth! - broken up into a bounding-volume hierarchy (BVH) of small pieces, called tiles. The main challenge of rendering a 3D Tiles tileset lies in deciding which tiles need to be loaded and rendered each frame, employing view-dependent culling and level-of-detail techniques. Fortunately, Cesium Native takes care of these details.
It's important to understand that Cesium Native doesn't actually do any rendering itself, though. Instead, it provides each tile in the form of an in-memory glTF model, and it's up to your integration to do the actual rendering. These glTF models are rendering-ready static meshes, so rendering them is relatively straightforward in most environments.
Sequence Walkthrough
In order to understand the pieces that you will need to implement in order to complete your integration, let's walk through a sequence of render frames and show what happens along the way. In this diagram:
  • Application is the application you're developing.
  • Tileset is the Cesium Native Tileset class.
  • IAssetAccessor is Cesium Native's interface to download assets, i.e., files on the file system or a web server. Cesium Native provides an implementation of this interface based on libcurl in CurlAssetAccessor. Or, if your application already has the ability to access network resources, you can implement the interface yourself.
  • IPrepareRendererResources is Cesium Native's interface to create "renderer" resources on-demand for the glTF models that it provides. For example, if you're integrating Cesium Native into a game engine, the renderer resource might be an instance of the game engine's static mesh class. You must implement this interface as well.
sequenceDiagram actor Application participant Tileset actor IAssetAccessor actor IPrepareRendererResources Note over Application,Tileset: Frame 1 Application->>Tileset: updateView Tileset->>Tileset: Select Tiles A, B Tileset-)IAssetAccessor: Start: get (Tile A) Tileset-)IAssetAccessor: Start: get (Tile B) Tileset-->>Application: Tiles to Render This Frame (None)
In Frame 1, your application calls updateView on the Tileset. It passes in all of the ViewStates from which the tileset is currently being viewed. A ViewState includes a position, a look direction, a camera "up" direction, a viewport width and height in pixels, and horizontal and vertical field-of-view angles. This is all the information that Cesium Native needs in order to decide which subset of the model is visible, and what level-of-detail is needed for each part. You'll likely create a ViewState from each camera in your scene.
Note
All of the ViewState instances together represent one view, and one set of tiles will be selected that satisfies all of them. It is also possible to select a different set of tiles in each view by using the updateViewGroup method instead of updateView. updateView simply calls updateViewGroup with the default view group. It also calls loadTiles in order to save the user the trouble of doing this themselves when only using a single view group.
In our example, based on the ViewStates, Cesium Native selects tiles A and B as being needed for rendering. The details of this process are described in the 3D Tiles Selection Algorithm, but aren't important for now. In Frame 1, no tiles are loaded yet, so Tileset calls IAssetAccessor::get to initiate the download of these two tiles. These downloads happen asynchronously via the AsyncSystem; Cesium Native doesn't wait for them to complete before continuing.
sequenceDiagram actor Application participant Tileset actor IAssetAccessor actor IPrepareRendererResources Note over Application,Tileset: Frame 2 Application->>Tileset: updateView IAssetAccessor--)Tileset: Resolve: get (Tile A) Tileset->>Tileset: Select Tiles A, B Tileset-)IPrepareRendererResources: Start: prepareInLoadThread (Tile A) Tileset-->>Application: Tiles to Render This Frame (None)
In Frame 2, your application calls updateView again, as it will every frame. If any views have changed since last frame, you should provide the new views, and Cesium Native will adapt accordingly.
At the start of the updateView, the Tileset happens to receive the asynchronous content for Tile A that it requested in Frame 1. It's entirely possible that this download could take multiple frames, or that it could complete in between calls to updateView, rather than completing for the next frame as we've shown here.
updateView runs the selection algorithm again, and once again selects Tiles A and B. Tileset is still waiting for content for Tile B, so it can't do anything more there. However, it's already received the content for Tile A, so it can start the next part of the process: prepareInLoadThread. As the name implies, this method is invoked from a background worker thread (dispatched using ITaskProcessor) and gives your integration its first opportunity to do renderer resource preparation for Tile A's glTF model.
Note
In most applications, it's possible to do some of the work necessary to prepare a static mesh for rendering in a background thread, but at least a small part of that work must be done in the application's "main" thread. That is why the glTF preparation process is split into two parts: prepareInLoadThread, which we've just seen, and prepareInMainThread, which we'll see in the next frame. Applications are free to divide the work between these two methods however they see fit. Some applications may not use one or the other of them at all.
sequenceDiagram actor Application participant Tileset actor IAssetAccessor actor IPrepareRendererResources Note over Application,Tileset: Frame 3 Application->>Tileset: updateView IPrepareRendererResources--)Tileset: Resolve: prepareInLoadThread (Tile A) IAssetAccessor--)Tileset: Resolve: get (Tile B) Tileset->>Tileset: Select Tiles A, B Tileset-)IPrepareRendererResources: Start: prepareInLoadThread (Tile B) Tileset->>IPrepareRendererResources: prepareInMainThread (Tile A) IPrepareRendererResources-->>Tileset: Renderer resources (Tile A) Tileset-->>Application: Tiles to Render This Frame (A)
In Frame 3, two asynchronous operations begun in previous frames resolve (complete successfully). The first is the prepareInLoadThread for Tile A, and the second is the download of Tile B's content. Tileset runs the selection algorithm again, and happens to come up with the same answer, selecting tiles A and B.
Now that Tileset has content for Tile B, it can initiate the prepareInLoadThread for Tile B, as it did for Tile A last frame. And now that the prepareInLoadThread has resolved for Tile A, Tileset can call prepareInMainThread for Tile A. Unlike prepareInLoadThread, prepareInMainThread is a synchronous operation that must complete and return before the work of updateView can continue. For this reason, it's important to keep prepareInMainThread as fast as possible!
Note
By "main thread", we mean the thread that called updateView. This does not necessarily have to be the thread that your application considers to be the main one. However, you must ensure that multiple threads do not access Tileset simultaneously. In Debug builds of Cesium Native, assertions will prevent you from calling updateView from different threads even if you ensure only one thread at a time is doing so, because this usually indicates a mistake and the potential for a subtle race condition.
prepareInLoadThread and prepareInMainThread should ensure that the renderer resources they create are initially not visible in the scene. This is important because some tiles are pre-loaded, before they're actually needed for rendering.
With Tile A selected and its loading complete, the Tileset will return it from updateView as one of the tilesToRenderThisFrame. Your application must look through the returned set of tiles and ensure that each is visible (rendered). Similarly, tiles in the tilesFadingOut should be hidden or faded out.
sequenceDiagram actor Application participant Tileset actor IAssetAccessor actor IPrepareRendererResources Note over Application,Tileset: Frame 4 Application->>Tileset: updateView IPrepareRendererResources--)Tileset: Resolve: prepareInLoadThread (Tile B) Tileset->>Tileset: Select Tile B Only Tileset->>IPrepareRendererResources: prepareInMainThread (Tile B) IPrepareRendererResources-->>Tileset: Renderer resources (Tile B) Tileset->>IPrepareRendererResources: free (Tile A) Tileset-->>Application: Tiles to Render This Frame (B)
In Frame 4, the prepareInLoadThread initiated for Tile B in Frame 3 resolves. When Tileset runs the selection algorithm, it learns that, because a view has moved, only Tile B is selected now. It calls prepareInMainThread on Tile B to prepare it for rendering.
Tileset also calls free to release the renderer resources that were created for Tile A in prepareInLoadThread and prepareInMainThread. Once the renderer resources are freed, the Tileset will release the glTF tile content as well. In practice, this free may or may not actually happen this frame. Cesium Native keeps some tiles around, up to a maximumCachedBytes specified in TilesetOptions, in case they are needed again soon. Cesium Native will ensure that the tiles it calls free on are not currently visible in the scene.
With that out of the way, Tileset returns the new set of tilesToRenderThisFrame (B). It will also include Tile A in the tilesFadingOut.
Implementing 3D Tiles Rendering
As illustrated above, integrating 3D Tiles rendering in your application requires the following:
  1. Implement ITaskProcessor to run jobs in background threads, preferably using a thread pool or task graph.
  2. Implement IAssetAccessor to download resources from whatever sources your application needs to load 3D Tiles from. A possible approach is to use libcurl via the CurlAssetAccessor included with Cesium Native, but many applications already include file and HTTP support.
  3. Implement IPrepareRendererResources to create meshes and textures for your application from the in-memory glTF representations provided by Cesium Native.
  4. When constructing a Tileset, pass in instances of the three implementations above as part of the TilesetExternals.
  5. Call updateView on each Tileset each frame. Show the already-created models identified in tilesToRenderThisFrame and hide the ones in tilesFadingOut.
In practice, the bulk of the work is usually in item (3). While glTF is a an efficient format for rendering, implementing a robust and performant pathway from a glTF to your applications rendering system can involve a fair bit of work. It's usually possible, however, to get the basics working relatively quickly.
