cesium-native 0.62.0
Represents a non-normalized array metadata property in EXT_structural_metadata. More...
#include <CesiumGltf/PropertyView.h>
| PropertyView () | |
| Constructs an empty property instance. | |
| PropertyView (const ClassProperty &classProperty) | |
| Constructs a property instance from a class definition only. | |
| PropertyView (const ClassProperty &classProperty, const CesiumGltf::Enum *pEnumDefinition) | |
| Constructs a property instance from a class definition and enum definition. | |
| PropertyViewStatusType | status () const noexcept |
| Constructs an empty property instance. false>status | |
| const std::optional< std::string > & | name () const noexcept |
| Constructs an empty property instance. false>name | |
| const std::optional< std::string > & | semantic () const noexcept |
| Constructs an empty property instance. false>semantic | |
| const std::optional< std::string > & | description () const noexcept |
| Constructs an empty property instance. false>description | |
| int64_t | arrayCount () const noexcept |
| Constructs an empty property instance. false>arrayCount | |
| bool | normalized () const noexcept |
| Constructs an empty property instance. false>normalized | |
| std::optional< PropertyArrayView< ElementType > > | offset () const noexcept |
| Constructs an empty property instance. false>offset | |
| std::optional< PropertyArrayView< ElementType > > | scale () const noexcept |
| Constructs an empty property instance. false>scale | |
| std::optional< PropertyArrayView< ElementType > > | max () const noexcept |
| Constructs an empty property instance. false>max | |
| std::optional< PropertyArrayView< ElementType > > | min () const noexcept |
| Constructs an empty property instance. false>min | |
| bool | required () const noexcept |
| Constructs an empty property instance. false>required | |
| std::optional< PropertyArrayView< ElementType > > | noData () const noexcept |
| Constructs an empty property instance. false>noData | |
| std::optional< PropertyArrayView< ElementType > > | defaultValue () const noexcept |
| Constructs an empty property instance. false>defaultValue | |
| PropertyType | propertyType () const noexcept |
| Returns the PropertyType of the property that this view is accessing. | |
| PropertyView (PropertyViewStatusType status) | |
| Constructs an invalid instance for an erroneous property. | |
| PropertyView (const ClassProperty &classProperty, const PropertyTableProperty &property, const CesiumGltf::Enum *pEnumDefinition=nullptr) | |
| Constructs a property instance from a property table property, its class definition, and an optional enum definition. | |
| PropertyView (const ClassProperty &classProperty, const PropertyTextureProperty &property, const CesiumGltf::Enum *pEnumDefinition=nullptr) | |
| Constructs a property instance from a property texture property, its class definition, and an optional enum definition. | |
Protected Attributes | |
| PropertyViewStatusType | _status |
| Indicates the status of a property view. | |
Whether they belong to property tables, property textures, or property attributes, properties have their own sub-properties affecting the actual property values. Although they are typically defined via class property, they may be overridden by individual instances of the property themselves. The constructor is responsible for resolving those differences.
| ElementType | The C++ type of the elements in the array values for this property. |
Definition at line 1504 of file PropertyView.h.
Definition at line 1509 of file PropertyView.h.
Definition at line 1527 of file PropertyView.h.
Definition at line 1534 of file PropertyView.h.
inlineprotected |
| status | The value of PropertyViewStatus indicating the error with the property. |
Definition at line 1613 of file PropertyView.h.
inlineprotected |
Definition at line 1632 of file PropertyView.h.
inlineprotected |
Definition at line 1651 of file PropertyView.h.
inlinenoexcept |
false>arrayCount
Definition at line 1694 of file PropertyView.h.
inlinenoexcept |
false>defaultValue
Definition at line 1749 of file PropertyView.h.
inlinenoexcept |
false>description
Definition at line 1687 of file PropertyView.h.
inlinenoexcept |
false>max
Definition at line 1720 of file PropertyView.h.
inlinenoexcept |
false>min
Definition at line 1728 of file PropertyView.h.
inlinenoexcept |
false>name
Definition at line 1675 of file PropertyView.h.
inlinenoexcept |
false>noData
Definition at line 1741 of file PropertyView.h.
inlinenoexcept |
false>normalized
Definition at line 1699 of file PropertyView.h.
inlinenoexcept |
false>offset
Definition at line 1704 of file PropertyView.h.
inlinenoexcept |
Definition at line 1759 of file PropertyView.h.
inlinenoexcept |
false>required
Definition at line 1736 of file PropertyView.h.
inlinenoexcept |
false>scale
Definition at line 1712 of file PropertyView.h.
inlinenoexcept |
false>semantic
Definition at line 1680 of file PropertyView.h.
inlinenoexcept |
false>status
Definition at line 1670 of file PropertyView.h.
protected |
The PropertyView constructor always completes successfully. However, there may be fundamental errors with the property definition. In such cases, this enumeration provides the reason.
This is defined with a class of static consts as opposed to an enum, so that derived property view classes can extend the statuses with their own specific errors.
Definition at line 1763 of file PropertyView.h.
