CesiumGltf::Enum Struct Referencefinal
This class is not meant to be instantiated directly. Use Enum instead. More...
#include <CesiumGltf/Enum.h>
Inheritance diagram for CesiumGltf::Enum:
CesiumGltf::EnumSpec CesiumUtility::ExtensibleObject
std::optional< std::string_view > getName (T enumValue) const
 Obtains the name corresponding to the given enum integer value from this enum definition.
- Public Member Functions inherited from CesiumGltf::EnumSpec
Additional Inherited Members
- Public Attributes inherited from CesiumGltf::EnumSpec
 The name of the enum, e.g. for display purposes.
 The description of the enum.
std::string valueType = ValueType::UINT16
 The type of the integer enum value.
std::vector< CesiumGltf::EnumValue > values
 An array of enum values. Duplicate names or duplicate integer values are not allowed.
- Static Public Attributes inherited from CesiumGltf::EnumSpec
static constexpr const char * TypeName = "Enum"
- Protected Member Functions inherited from CesiumGltf::EnumSpec
 EnumSpec ()=default
Definition at line 12 of file Enum.h.
◆ getName()
std::optional< std::string_view > CesiumGltf::Enum::getName ( T enumValue) const
enumValueThe enum value to resolve into a name.
The name in the enum definition corresponding to this value, or an empty string if the value cannot be found in the definition.
Definition at line 24 of file Enum.h.
