CesiumGltf::PropertyTextureView Class Reference
A view on a PropertyTexture. More...
#include <CesiumGltf/PropertyTextureView.h>
 PropertyTextureView (const Model &model, const PropertyTexture &propertyTexture) noexcept
 Construct a PropertyTextureView.
PropertyTextureViewStatus status () const noexcept
 Gets the status of this property texture view.
const std::optional< std::string > & name () const noexcept
 Gets the name of the property texture being viewed. Returns std::nullopt if no name was specified.
const Class * getClass () const noexcept
 Gets the Class that this property texture conforms to.
const ClassProperty * getClassProperty (const std::string &propertyId) const
 Finds the ClassProperty that describes the type information of the property with the specified id.
template<typename T, bool Normalized = false>
PropertyTexturePropertyView< T, Normalized > getPropertyView (const std::string &propertyId, const TextureViewOptions &propertyOptions=TextureViewOptions()) const
 Gets a PropertyTexturePropertyView that views the data of a property stored in the PropertyTexture.
template<typename Callback>
void getPropertyView (const std::string &propertyId, Callback &&callback, const TextureViewOptions &propertyOptions=TextureViewOptions()) const
 Gets a PropertyTexturePropertyView through a callback that accepts a property id and a PropertyTexturePropertyView that views the data of the property with the specified id.
void forEachProperty (Callback &&callback, const TextureViewOptions &propertyOptions=TextureViewOptions()) const
 Iterates over each property in the PropertyTexture with a callback that accepts a property id and a PropertyTexturePropertyView to view the data stored in the PropertyTextureProperty.
This should be used to get a PropertyTexturePropertyView of a property in the property texture. It will validate the EXT_structural_metadata format and ensure PropertyTexturePropertyView does not access data out of bounds.
Definition at line 51 of file PropertyTextureView.h.
◆ PropertyTextureView()
CesiumGltf::PropertyTextureView::PropertyTextureView ( const Model & model,
const PropertyTexture & propertyTexture )
noexcept
modelThe glTF that contains the property texture's data.
propertyTextureThe PropertyTexture from which the view will retrieve data.
◆ forEachProperty()
void CesiumGltf::PropertyTextureView::forEachProperty ( Callback && callback,
const TextureViewOptions & propertyOptions = TextureViewOptions() ) const
This method will validate the EXT_structural_metadata format to ensure PropertyTexturePropertyView retrieves the correct data. T must be a scalar with a supported component type (int8_t, uint8_t, int16_t, uint16_t, int32_t, uint32_t, float), a glm vecN composed of one of the scalar types, or a PropertyArrayView containing one of the scalar types.
If the property is invalid, an empty PropertyTexturePropertyView with an error status will be passed to the callback. Otherwise, a valid property view will be passed to the callback.
callbackA callback function that accepts property id and PropertyTexturePropertyView
propertyOptionsThe options to apply to each property in the property texture.
Template Parameters
CallbackThe type of the callback function.
Definition at line 294 of file PropertyTextureView.h.
◆ getClass()
const Class * CesiumGltf::PropertyTextureView::getClass ( ) const
inlinenoexcept
A pointer to the Class. Returns nullptr if the PropertyTexture did not specify a valid class.
Definition at line 86 of file PropertyTextureView.h.
◆ getClassProperty()
const ClassProperty * CesiumGltf::PropertyTextureView::getClassProperty ( const std::string & propertyId) const
propertyIdThe id of the property to retrieve the class for.
A pointer to the ClassProperty. Return nullptr if the PropertyTextureView is invalid or if no class property was found.
◆ getPropertyView() [1/2]
void CesiumGltf::PropertyTextureView::getPropertyView ( const std::string & propertyId,
If the property is somehow invalid, an empty PropertyTexturePropertyView with an error status will be passed to the callback. Otherwise, a valid property view will be passed to the callback.
propertyIdThe id of the property to retrieve data from
callbackA callback function that accepts a property id and a PropertyTexturePropertyView
propertyOptionsThe options to apply to the property.
Template Parameters
Definition at line 165 of file PropertyTextureView.h.
◆ getPropertyView() [2/2]
PropertyTexturePropertyView< T, Normalized > CesiumGltf::PropertyTextureView::getPropertyView ( const std::string & propertyId,
If T does not match the type specified by the class property, this returns an invalid PropertyTexturePropertyView. Likewise, if the value of Normalized does not match the value of ClassProperty::normalized for that class property, this returns an invalid property view. Only types with integer components may be normalized.
Template Parameters
TThe C++ type corresponding to the type of the data retrieved.
NormalizedWhether the property is normalized. Only applicable to types with integer components.
propertyIdThe ID of the property to retrieve data from
A PropertyTexturePropertyView of the property. If no valid property is found, the property view will be invalid.
Definition at line 123 of file PropertyTextureView.h.
◆ name()
const std::optional< std::string > & CesiumGltf::PropertyTextureView::name ( ) const
inlinenoexcept
Definition at line 76 of file PropertyTextureView.h.
◆ status()
PropertyTextureViewStatus CesiumGltf::PropertyTextureView::status ( ) const
inlinenoexcept
Indicates whether the view accurately reflects the property texture's data, or whether an error occurred.
Definition at line 70 of file PropertyTextureView.h.
