RasterMappedTo3DTile.h
3#include <Cesium3DTilesSelection/IPrepareRendererResources.h>
4#include <CesiumGeometry/Rectangle.h>
5#include <CesiumGeospatial/Projection.h>
6#include <CesiumRasterOverlays/RasterOverlayTile.h>
7#include <CesiumUtility/IntrusivePointer.h>
9#include <memory>
10
11namespace CesiumRasterOverlays {
13}
14
15namespace Cesium3DTilesSelection {
16
17class Tile;
18
28public:
33 enum class AttachmentState {
38
44
49 };
50
62 int32_t textureCoordinateIndex);
63
74 return this->_pLoadingTile.get();
75 }
76
79 getLoadingTile() const noexcept {
80 return this->_pLoadingTile.get();
81 }
82
92 return this->_pReadyTile.get();
93 }
94
97 return this->_pReadyTile.get();
98 }
99
108 int32_t getTextureCoordinateID() const noexcept {
109 return this->_textureCoordinateID;
110 }
111
119 void setTextureCoordinateID(int32_t textureCoordinateID) noexcept {
120 this->_textureCoordinateID = textureCoordinateID;
121 }
122
132 const glm::dvec2& getTranslation() const noexcept {
133 return this->_translation;
134 }
135
145 const glm::dvec2& getScale() const noexcept { return this->_scale; }
146
156 AttachmentState getState() const noexcept { return this->_state; }
157
172 update(IPrepareRendererResources& prepareRendererResources, Tile& tile);
173
177 bool isMoreDetailAvailable() const noexcept;
178
186 IPrepareRendererResources& prepareRendererResources,
187 Tile& tile) noexcept;
188
199 bool loadThrottled() noexcept;
200
231 double maximumScreenSpaceError,
232 CesiumRasterOverlays::ActivatedRasterOverlay& activatedOverlay,
233 Tile& tile,
234 std::vector<CesiumGeospatial::Projection>& missingProjections,
235 const CesiumGeospatial::Ellipsoid& ellipsoid CESIUM_DEFAULT_ELLIPSOID);
236
237private:
238 void computeTranslationAndScale(const Tile& tile);
239
240 CesiumUtility::IntrusivePointer<CesiumRasterOverlays::RasterOverlayTile>
241 _pLoadingTile;
242 CesiumUtility::IntrusivePointer<CesiumRasterOverlays::RasterOverlayTile>
243 _pReadyTile;
244 int32_t _textureCoordinateID;
245 glm::dvec2 _translation;
246 glm::dvec2 _scale;
247 AttachmentState _state;
248 bool _originalFailed;
249};
250
251} // namespace Cesium3DTilesSelection
When implemented for a rendering engine, allows renderer resources to be created and destroyed under ...
const CesiumRasterOverlays::RasterOverlayTile * getReadyTile() const noexcept
Returns the CesiumRasterOverlays::RasterOverlayTile that represents the imagery data that is ready to...
CesiumRasterOverlays::RasterOverlayTile * getLoadingTile() noexcept
Returns a CesiumRasterOverlays::RasterOverlayTile that is currently loading.
AttachmentState
The states indicating whether the raster tile is attached to the geometry.
@ Attached
This raster tile is attached to the geometry.
@ TemporarilyAttached
This raster tile is attached to the geometry, but it is a temporary, low-res version usable while the...
@ Unattached
This raster tile is not yet attached to the geometry at all.
Indicates whether this overlay tile is currently attached to its owning geometry tile.
static RasterMappedTo3DTile * mapOverlayToTile(double maximumScreenSpaceError, CesiumRasterOverlays::ActivatedRasterOverlay &activatedOverlay, Tile &tile, std::vector< CesiumGeospatial::Projection > &missingProjections, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84)
Creates a maping between a CesiumRasterOverlays::RasterOverlay and a Tile.
const glm::dvec2 & getScale() const noexcept
Returns the scaling that converts between the geometry texture coordinates and the texture coordinate...
Returns an identifier for the texture coordinates of this tile.
const glm::dvec2 & getTranslation() const noexcept
Returns the translation that converts between the geometry texture coordinates and the texture coordi...
RasterMappedTo3DTile(const CesiumUtility::IntrusivePointer< CesiumRasterOverlays::RasterOverlayTile > &pRasterTile, int32_t textureCoordinateIndex)
Creates a new instance.
Sets the texture coordinate ID.
Does a throttled load of the mapped CesiumRasterOverlays::RasterOverlayTile.
Determines if more detailed data is available for the spatial area covered by this tile.
CesiumRasterOverlays::RasterOverlayTile::MoreDetailAvailable update(IPrepareRendererResources &prepareRendererResources, Tile &tile)
Update this tile during the update of its owner.
CesiumRasterOverlays::RasterOverlayTile * getReadyTile() noexcept
void detachFromTile(IPrepareRendererResources &prepareRendererResources, Tile &tile) noexcept
Detach the raster from the given tile.
const CesiumRasterOverlays::RasterOverlayTile * getLoadingTile() const noexcept
A tile in a Tileset.
Definition Tile.h:123
A RasterOverlay that has been activated for use. While a RasterOverlayTileProvider can be used direct...
Raster image data for a tile in a quadtree.
MoreDetailAvailable
Tile availability states.
Classes for geospatial computations in Cesium.
Classes for raster overlays, which allow draping massive 2D textures over a model.
Utility classes for Cesium.
STL namespace.
