WebMercatorProjection.h
3#include <CesiumGeospatial/Ellipsoid.h>
4#include <CesiumGeospatial/GlobeRectangle.h>
5#include <CesiumGeospatial/Library.h>
6
7#include <glm/vec2.hpp>
8#include <glm/vec3.hpp>
9
10namespace CesiumGeospatial {
11
12class Cartographic;
13
24class CESIUMGEOSPATIAL_API WebMercatorProjection final {
25public:
40 static const double MAXIMUM_LATITUDE;
41
48
58 const Ellipsoid& ellipsoid CESIUM_DEFAULT_ELLIPSOID) noexcept {
59 const double value =
60 ellipsoid.getMaximumRadius() * CesiumUtility::Math::OnePi;
61 return CesiumGeometry::Rectangle(-value, -value, value, value);
62 }
63
70 const Ellipsoid& ellipsoid CESIUM_DEFAULT_ELLIPSOID) noexcept;
71
75 const Ellipsoid& getEllipsoid() const noexcept { return this->_ellipsoid; }
76
87 glm::dvec3 project(const Cartographic& cartographic) const noexcept;
88
98 project(const CesiumGeospatial::GlobeRectangle& rectangle) const noexcept;
99
111 Cartographic unproject(const glm::dvec2& projectedCoordinates) const noexcept;
112
124 Cartographic unproject(const glm::dvec3& projectedCoordinates) const noexcept;
125
135 unproject(const CesiumGeometry::Rectangle& rectangle) const noexcept;
136
144 static double mercatorAngleToGeodeticLatitude(double mercatorAngle) noexcept;
145
153 static double geodeticLatitudeToMercatorAngle(double latitude) noexcept;
154
158 bool operator==(const WebMercatorProjection& rhs) const noexcept {
159 return this->_ellipsoid == rhs._ellipsoid;
160 };
161
166 bool operator!=(const WebMercatorProjection& rhs) const noexcept {
167 return !(*this == rhs);
168 };
169
170private:
171 Ellipsoid _ellipsoid;
172 double _semimajorAxis;
173 double _oneOverSemimajorAxis;
174};
175
176} // namespace CesiumGeospatial
A position defined by longitude, latitude, and height.
Definition Ellipsoid.h:39
A two-dimensional, rectangular region on a globe, specified using longitude and latitude coordinates....
bool operator==(const WebMercatorProjection &rhs) const noexcept
Returns true if two projections (i.e. their ellipsoids) are equal.
static const GlobeRectangle MAXIMUM_GLOBE_RECTANGLE
The maximum bounding rectangle of the Web Mercator projection, ranging from -PI to PI radians longitu...
CesiumGeospatial::GlobeRectangle unproject(const CesiumGeometry::Rectangle &rectangle) const noexcept
Unprojects a Web Mercator rectangle to the globe.
const Ellipsoid & getEllipsoid() const noexcept
Gets the Ellipsoid.
CesiumGeometry::Rectangle project(const CesiumGeospatial::GlobeRectangle &rectangle) const noexcept
Projects a globe rectangle to Web Mercator coordinates.
WebMercatorProjection(const Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) noexcept
Converts a geodetic latitude in radians, in the range -PI/2 to PI/2, to a Mercator angle in the range...
Cartographic unproject(const glm::dvec3 &projectedCoordinates) const noexcept
Converts Web Mercator coordinates to geodetic ellipsoid coordinates.
static constexpr CesiumGeometry::Rectangle computeMaximumProjectedRectangle(const Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) noexcept
Computes the maximum rectangle that can be covered with this projection.
The maximum latitude (both North and South) supported by a Web Mercator (EPSG:3857) projection.
Cartographic unproject(const glm::dvec2 &projectedCoordinates) const noexcept
bool operator!=(const WebMercatorProjection &rhs) const noexcept
Returns true if two projections (i.e. their ellipsoids) are not equal.
Converts a Mercator angle, in the range -PI to PI, to a geodetic latitude in the range -PI/2 to PI/2.
glm::dvec3 project(const Cartographic &cartographic) const noexcept
Converts geodedic ellipsoid coordinates to Web Mercator coordinates.
static constexpr double OnePi
Pi.
Definition Math.h:81
Classes for geospatial computations in Cesium.
A 2D rectangle.
Definition Rectangle.h:14
