IonRasterOverlay.h
3#include <CesiumAsync/IAssetRequest.h>
4#include <CesiumAsync/NetworkAssetDescriptor.h>
5#include <CesiumAsync/SharedAssetDepot.h>
6#include <CesiumGeospatial/Ellipsoid.h>
7#include <CesiumRasterOverlays/Library.h>
8#include <CesiumRasterOverlays/RasterOverlay.h>
9#include <CesiumUtility/SharedAsset.h>
10
11#include <chrono>
12#include <memory>
13#include <optional>
14#include <string>
15#include <unordered_map>
16#include <variant>
17#include <vector>
18
19namespace CesiumRasterOverlays {
20
24class CESIUMRASTEROVERLAYS_API IonRasterOverlay : public RasterOverlay {
25public:
41 const std::string& name,
42 int64_t ionAssetID,
43 const std::string& ionAccessToken,
44 const RasterOverlayOptions& overlayOptions = {},
45 const std::string& ionAssetEndpointUrl = "https://api.cesium.com/");
46 virtual ~IonRasterOverlay() override;
47
54 const std::optional<std::string>& getAssetOptions() const noexcept;
55
62 void setAssetOptions(const std::optional<std::string>& options) noexcept;
63
66 const override;
67
68protected:
85 const std::string& name,
86 const std::string& overlayUrl,
87 const std::string& ionAccessToken,
88 bool needsAuthHeader,
89 const RasterOverlayOptions& overlayOptions = {});
90
91private:
92 std::string _overlayUrl;
93 std::string _ionAccessToken;
94 bool _needsAuthHeader;
95 std::optional<std::string> _assetOptions;
96
97 class TileProvider;
98
99 struct AssetEndpointAttribution {
100 std::string html;
101 bool collapsible = true;
102 };
103
104 struct ExternalAssetEndpoint
105 : public CesiumUtility::SharedAsset<ExternalAssetEndpoint> {
106 ExternalAssetEndpoint() noexcept = default;
107 ~ExternalAssetEndpoint() noexcept = default;
108 ExternalAssetEndpoint(const ExternalAssetEndpoint&) noexcept = default;
109 ExternalAssetEndpoint(ExternalAssetEndpoint&&) noexcept = default;
110
111 std::chrono::steady_clock::time_point requestTime{};
112 std::string externalType{};
113 std::vector<AssetEndpointAttribution> attributions{};
114 std::shared_ptr<CesiumAsync::IAssetRequest> pRequestThatFailed{};
115
117 struct TileMapService {
118 std::string url;
119 std::string accessToken;
120 };
121
123 struct Azure2D {
124 std::string url;
125 std::string tilesetId;
126 std::string key;
127 };
128
130 struct Google2D {
131 std::string url;
132 std::string key;
133 std::string session;
134 std::string expiry;
135 std::string imageFormat;
136 uint32_t tileWidth;
137 uint32_t tileHeight;
138 };
139
141 struct Bing {
142 std::string key;
143 std::string url;
144 std::string mapStyle;
145 std::string culture;
146 };
147
148 std::variant<std::monostate, TileMapService, Azure2D, Google2D, Bing>
149 options{};
150
151 void parseAzure2DOptions(const rapidjson::Document& ionResponse);
152 void parseGoogle2DOptions(const rapidjson::Document& ionResponse);
153 void parseBingOptions(const rapidjson::Document& ionResponse);
154 void parseTileMapServiceOptions(const rapidjson::Document& ionResponse);
155 };
156
157 static std::unordered_map<std::string, ExternalAssetEndpoint> endpointCache;
158
159 using EndpointDepot = CesiumAsync::SharedAssetDepot<
160 ExternalAssetEndpoint,
161 CesiumAsync::NetworkAssetDescriptor,
162 RasterOverlayExternals>;
163
164 static CesiumUtility::IntrusivePointer<EndpointDepot> getEndpointCache();
165};
166
167} // namespace CesiumRasterOverlays
A RasterOverlay that obtains imagery data from Cesium ion.
void setAssetOptions(const std::optional< std::string > &options) noexcept
Sets the additional options to be passed to the asset endpoint.
const std::optional< std::string > & getAssetOptions() const noexcept
Gets the additional options to be passed to the asset endpoint.
virtual CesiumAsync::Future< CreateTileProviderResult > createTileProvider(const CreateRasterOverlayTileProviderParameters &parameters) const override
Begins asynchronous creation of a tile provider for this overlay and eventually returns it via a Futu...
IonRasterOverlay(const std::string &name, int64_t ionAssetID, const std::string &ionAccessToken, const RasterOverlayOptions &overlayOptions={}, const std::string &ionAssetEndpointUrl="https://api.cesium.com/")
Creates a new instance.
RasterOverlay(const std::string &name, const RasterOverlayOptions &overlayOptions=RasterOverlayOptions())
nonstd::expected< CesiumUtility::IntrusivePointer< RasterOverlayTileProvider >, RasterOverlayLoadFailureDetails > CreateTileProviderResult
A result from a call to createTileProvider. This is expected to be an IntrusivePointer to a RasterOve...
An asset that is potentially shared between multiple objects, such as an image shared between multipl...
Definition SharedAsset.h:55
Classes that support asynchronous operations.
@ Bing
Bing geocoder, for use with Bing data.
Definition Geocoder.h:44
Classes for raster overlays, which allow draping massive 2D textures over a model.
@ TileProvider
An initial load needed to create the overlay's tile provider.
STL namespace.
Options for loading raster overlays.
