cesium-native 0.67.0
Classes for working with Cesium ion clients. More...
Classes | |
| struct | ApplicationData |
| Data retrieved from the Cesium ion server via an "appData" request from Cesium ion. This actually represents information about the server itself. More... | |
| struct | Asset |
| A Cesium ion Asset, such as a 3D Tiles tileset or an imagery layer. More... | |
| struct | Assets |
A page of assets obtained from the Cesium ion v1/assets endpoint, including a link to obtain the next page, if one exists. More... | |
| class | Connection |
| A connection to Cesium ion that can be used to interact with it via its REST API. More... | |
| struct | DefaultAssets |
| The default assets. More... | |
| struct | Defaults |
The data returned by Cesium ion's v1/defaults service. It includes information about default imagery, terrain and building assets along with quick add assets that can be useful to use within other applications. More... | |
| struct | GeocoderAttribution |
| Attribution information for a query to a geocoder service. More... | |
| struct | GeocoderFeature |
| A single feature (a location or region) obtained from a geocoder service. More... | |
| struct | GeocoderResult |
| The result of making a request to a geocoder service. More... | |
| struct | ListTokensOptions |
| Options to be passed to Connection::tokens. More... | |
| class | LoginToken |
| A login token for interacting with the Cesium ion REST API, obtained from the OAuth authentication flow. More... | |
| struct | NoValue |
| A non-value, for use with a valueless Response. More... | |
| struct | Profile |
| Contains of a Cesium ion user. More... | |
| struct | ProfileStorage |
| Information about the amount of storage available in a user's account. More... | |
| struct | QuickAddAsset |
| A quick add asset. More... | |
| struct | QuickAddRasterOverlay |
| A raster overlay available for use with a quick add asset. More... | |
| struct | Response |
| A response from Cesium ion. More... | |
| struct | Token |
| A Cesium ion access token. More... | |
| struct | TokenList |
| A list of Cesium ion access tokens, as returned by the "List Tokens" service. More... | |
Enumerations | |
| enum | AuthenticationMode { CesiumIon , Saml , SingleUser } |
An enumeration representing the values of the authenticationMode property in the appData response. More... | |
| enum class | SortOrder { Ascending , Descending } |
| Whether sorted results should be ascending or descending. More... | |
| enum | GeocoderRequestType { Search , Autocomplete } |
| The supported types of requests to geocoding API. More... | |
| enum | GeocoderProviderType { Google , Bing , Default } |
| The supported providers that can be accessed through ion's geocoder API. More... | |
| Enumerator | |
| CesiumIon | Authentication using OAuth with an ion.cesium.com account. |
| Saml | Authentication using OAuth with Cesium ion Self-Hosted. On the server, this uses the Security Assertion Markup Language (SAML) to communicate with another authentication server. From our perspective, we can treat this the same as AuthenticationMode::CesiumIon. |
| SingleUser | A Cesium ion Self-Hosted server without authentication. In single-user mode, any application that can reach the server has permissions to use its endpoints. In this mode, some endpoints (like /me and /tokens) are unavailable. |
Definition at line 11 of file ApplicationData.h.
Definition at line 35 of file Geocoder.h.
| Enumerator | |
| Search | Perform a full search from a complete query. |
| Autocomplete | Perform a quick search based on partial input, such as while a user is typing. The search results may be less accurate or exhaustive than using GeocoderRequestType::Search. |
Definition at line 16 of file Geocoder.h.
strong |
Definition at line 29 of file Connection.h.
