UCesiumGoogleMapTilesRasterOverlay Class Reference
A raster overlay that directly accesses Google Map Tiles (2D). More...
#include <CesiumGoogleMapTilesRasterOverlay.h>
Inheritance diagram for UCesiumGoogleMapTilesRasterOverlay:
UCesiumRasterOverlay
FString Key
 The Google Map Tiles API key to use.
EGoogleMapTilesMapType MapType = EGoogleMapTilesMapType::Satellite
 The type of base map.
FString Language = "en-US"
 An IETF language tag that specifies the language used to display information on the tiles.
FString Region = "US"
 A Common Locale Data Repository region identifier (two uppercase letters) that represents the physical location of the user.
EGoogleMapTilesScale Scale = EGoogleMapTilesScale::ScaleFactor1x
 Scales-up the size of map elements (such as road labels), while retaining the tile size and coverage area of the default tile.
bool HighDPI = false
 Specifies whether to return high-resolution tiles.
TArray< EGoogleMapTilesLayerType > LayerTypes
 The layer types to be added to the map.
TArray< FString > Styles
 An array of JSON style objects that specify the appearance and detail level of map features such as roads, parks, and built-up areas.
bool Overlay = false
 Specifies whether LayerTypes rendered as a separate overlay, or combined with the base imagery.
- Public Attributes inherited from UCesiumRasterOverlay
FString MaterialLayerKey = "Overlay0"
 The key to use to match this overlay to a material layer.
FRasterOverlayRendererOptions rendererOptions
 Sets the texture filter and texture group of raster tile images.
Protected Member Functions
virtual std::unique_ptr< CesiumRasterOverlays::RasterOverlay > CreateOverlay (const CesiumRasterOverlays::RasterOverlayOptions &options={}) override
- Protected Member Functions inherited from UCesiumRasterOverlay
Cesium3DTilesSelection::Tileset * FindTileset () const
virtual void OnAdd (Cesium3DTilesSelection::Tileset *pTileset, CesiumRasterOverlays::RasterOverlay *pOverlay)
virtual void OnRemove (Cesium3DTilesSelection::Tileset *pTileset, CesiumRasterOverlays::RasterOverlay *pOverlay)
Additional Inherited Members
- Public Member Functions inherited from UCesiumRasterOverlay
 UCesiumRasterOverlay ()
void AddToTileset ()
 Displays this raster overlay on its owning Cesium 3D Tileset Actor, without changing its activation state.
void RemoveFromTileset ()
 Stops displaying this raster overlay on its owning Cesium 3D Tileset Actor.
void Refresh ()
double GetMaximumScreenSpaceError () const
void SetMaximumScreenSpaceError (double Value)
int32 GetMaximumTextureSize () const
void SetMaximumTextureSize (int32 Value)
int32 GetMaximumSimultaneousTileLoads () const
void SetMaximumSimultaneousTileLoads (int32 Value)
int64 GetSubTileCacheBytes () const
void SetSubTileCacheBytes (int64 Value)
 Activates this raster overlay, which will display it on the Cesium3DTileset to which the component is attached, if it isn't already displayed.
 Deactivates this raster overlay.
virtual bool IsReadyForFinishDestroy () override
- Protected Attributes inherited from UCesiumRasterOverlay
double MaximumScreenSpaceError = 2.0
int32 MaximumTextureSize = 2048
int32 MaximumSimultaneousTileLoads = 20
int64 SubTileCacheBytes = 16 * 1024 * 1024
bool ShowCreditsOnScreen
 Whether or not to show credits of this raster overlay on screen.
If you're using Google Map Tiles via Cesium ion, use the "Cesium ion Raster Overlay" component instead.
Definition at line 82 of file CesiumGoogleMapTilesRasterOverlay.h.
◆ CreateOverlay()
virtual std::unique_ptr< CesiumRasterOverlays::RasterOverlay > UCesiumGoogleMapTilesRasterOverlay::CreateOverlay ( const CesiumRasterOverlays::RasterOverlayOptions & options = {})
overrideprotectedvirtual
◆ HighDPI
bool UCesiumGoogleMapTilesRasterOverlay::HighDPI = false
If the scale-factor is increased, highDpi is used to increase the size of the tile. Normally, increasing the scale factor enlarges the resulting tile into an image of the same size, which lowers quality. With highDpi, the resulting size is also increased, preserving quality. DPI stands for Dots per Inch, and High DPI means the tile renders using more dots per inch than normal. If true, then the number of pixels in each of the x and y dimensions is multiplied by the scale factor (that is , 2x or 4x). The coverage area of the tile remains unchanged. This parameter works only with Scale values of 2x or 4x. It has no effect on 1x scale tiles.
Definition at line 138 of file CesiumGoogleMapTilesRasterOverlay.h.
◆ Key
FString UCesiumGoogleMapTilesRasterOverlay::Key
Definition at line 91 of file CesiumGoogleMapTilesRasterOverlay.h.
◆ Language
FString UCesiumGoogleMapTilesRasterOverlay::Language = "en-US"
For example, en-US specifies the English language as spoken in the United States.
Definition at line 105 of file CesiumGoogleMapTilesRasterOverlay.h.
◆ LayerTypes
TArray<EGoogleMapTilesLayerType> UCesiumGoogleMapTilesRasterOverlay::LayerTypes
Definition at line 144 of file CesiumGoogleMapTilesRasterOverlay.h.
◆ MapType
EGoogleMapTilesMapType UCesiumGoogleMapTilesRasterOverlay::MapType = EGoogleMapTilesMapType::Satellite
Definition at line 97 of file CesiumGoogleMapTilesRasterOverlay.h.
◆ Overlay
bool UCesiumGoogleMapTilesRasterOverlay::Overlay = false
When true, the base map isn't displayed. If you haven't defined any LayerTypes, then this value is ignored.
Definition at line 166 of file CesiumGoogleMapTilesRasterOverlay.h.
◆ Region
FString UCesiumGoogleMapTilesRasterOverlay::Region = "US"
For example, US.
Definition at line 112 of file CesiumGoogleMapTilesRasterOverlay.h.
◆ Scale
EGoogleMapTilesScale UCesiumGoogleMapTilesRasterOverlay::Scale = EGoogleMapTilesScale::ScaleFactor1x
Increasing the scale also reduces the number of labels on the map, which reduces clutter.
Definition at line 122 of file CesiumGoogleMapTilesRasterOverlay.h.
◆ Styles
TArray<FString> UCesiumGoogleMapTilesRasterOverlay::Styles
Styling is used to customize the standard Google base map. The styles parameter is valid only if the MapType is Roadmap. For the complete style syntax, see the Style Reference.
Definition at line 156 of file CesiumGoogleMapTilesRasterOverlay.h.
