CesiumTilesetJson::Tileset Struct Reference
This class is not meant to be instantiated directly. Use Tileset instead. More...
#include <CesiumTilesetJson/Tileset.h>
Inheritance diagram for CesiumTilesetJson::Tileset:
CesiumTilesetJson::TilesetSpec CesiumUtility::ExtensibleObject
Public Types
typedef void ForEachTileCallback(Tileset &tileset, Tile &tile, const glm::dmat4 &transform, const std::string &refine)
 A callback function for forEachTile.
typedef void ForEachTileConstCallback(const Tileset &tileset, const Tile &tile, const glm::dmat4 &transform, const std::string &refine)
typedef void ForEachContentCallback(Tileset &tileset, Tile &tile, Content &content, const glm::dmat4 &transform, const std::string &refine)
 A callback function for forEachContent.
typedef void ForEachContentConstCallback(const Tileset &tileset, const Tile &tile, const Content &content, const glm::dmat4 &transform, const std::string &refine)
void forEachTile (std::function< ForEachTileCallback > &&callback)
 Apply the given callback to all tiles.
void forEachTile (std::function< ForEachTileConstCallback > &&callback) const
void forEachContent (std::function< ForEachContentCallback > &&callback)
 Apply the given callback to all contents.
void forEachContent (std::function< ForEachContentConstCallback > &&callback) const
void addExtensionUsed (const std::string &extensionName)
 Adds an extension to the TilesetSpec::extensionsUsed property, if it is not already present.
void addExtensionRequired (const std::string &extensionName)
 Adds an extension to the TilesetSpec::extensionsRequired property, if it is not already present.
void removeExtensionUsed (const std::string &extensionName)
 Removes an extension from the TilesetSpec::extensionsUsed property.
void removeExtensionRequired (const std::string &extensionName)
 Removes an extension from the TilesetSpec::extensionsRequired property.
bool isExtensionUsed (const std::string &extensionName) const noexcept
 Determines whether a given extension name is listed in the tileset's TilesetSpec::extensionsUsed property.
bool isExtensionRequired (const std::string &extensionName) const noexcept
 Determines whether a given extension name is listed in the tileset's TilesetSpec::extensionsRequired property.
- Public Member Functions inherited from CesiumTilesetJson::TilesetSpec
Additional Inherited Members
- Public Attributes inherited from CesiumTilesetJson::TilesetSpec
CesiumTilesetJson::Asset asset
std::unordered_map< std::string, CesiumTilesetJson::Properties > properties
 A dictionary object of metadata about per-feature properties.
std::optional< CesiumTilesetJson::Schema > schema
 An object defining the structure of metadata classes and enums. When this is defined, then schemaUri shall be undefined.
std::optional< std::string > schemaUri
 The URI (or IRI) of the external schema file. When this is defined, then schema shall be undefined.
std::optional< CesiumTilesetJson::Statistics > statistics
 An object containing statistics about metadata entities.
std::vector< CesiumTilesetJson::GroupMetadata > groups
 An array of groups that tile content may belong to. Each element of this array is a metadata entity that describes the group. The tile content group property is an index into this array.
std::optional< CesiumTilesetJson::MetadataEntity > metadata
 A metadata entity that is associated with this tileset.
double geometricError = double()
 The error, in meters, introduced if this tileset is not rendered. At runtime, the geometric error is used to compute screen space error (SSE), i.e., the error measured in pixels.
CesiumTilesetJson::Tile root
 The root tile.
std::vector< std::string > extensionsUsed
 Names of 3D Tiles extensions used somewhere in this tileset.
std::vector< std::string > extensionsRequired
 Names of 3D Tiles extensions required to properly load this tileset. Each element of this array shall also be contained in extensionsUsed.
- Static Public Attributes inherited from CesiumTilesetJson::TilesetSpec
static constexpr const char * TypeName = "Tileset"
- Protected Member Functions inherited from CesiumTilesetJson::TilesetSpec
 TilesetSpec ()=default
Definition at line 13 of file Tileset.h.
Member Typedef Documentation
◆ ForEachContentCallback
typedef void CesiumTilesetJson::Tileset::ForEachContentCallback(Tileset &tileset, Tile &tile, Content &content, const glm::dmat4 &transform, const std::string &refine)
tilesetThe tileset.
tileThe tile.
contentThe content.
transformThe tile's world transform, computed from the product of the parent's world transform and the tile's local transform.
refineThe tile's refine property, potentially inherited from an ancestor tile if not set.
Definition at line 63 of file Tileset.h.
◆ ForEachContentConstCallback
typedef void CesiumTilesetJson::Tileset::ForEachContentConstCallback(const Tileset &tileset, const Tile &tile, const Content &content, const glm::dmat4 &transform, const std::string &refine)
tilesetThe tileset.
tileThe tile.
contentThe content.
Definition at line 81 of file Tileset.h.
◆ ForEachTileCallback
typedef void CesiumTilesetJson::Tileset::ForEachTileCallback(Tileset &tileset, Tile &tile, const glm::dmat4 &transform, const std::string &refine)
tilesetThe tileset.
tileThe tile.
Definition at line 26 of file Tileset.h.
◆ ForEachTileConstCallback
typedef void CesiumTilesetJson::Tileset::ForEachTileConstCallback(const Tileset &tileset, const Tile &tile, const glm::dmat4 &transform, const std::string &refine)
tilesetThe tileset.
tileThe tile.
Definition at line 43 of file Tileset.h.
◆ addExtensionRequired()
void CesiumTilesetJson::Tileset::addExtensionRequired ( const std::string & extensionName)
Calling this function also adds the extension to extensionsUsed, if it's not already present.
extensionNameThe name of the required extension.
◆ addExtensionUsed()
void CesiumTilesetJson::Tileset::addExtensionUsed ( const std::string & extensionName)
extensionNameThe name of the used extension.
◆ forEachContent() [1/2]
void CesiumTilesetJson::Tileset::forEachContent ( std::function< ForEachContentCallback > && callback)
This will only invoke the callback for contents of explicit tiles. It won't follow external tilesets or implicit tiles.
callbackThe callback to apply
◆ forEachContent() [2/2]
void CesiumTilesetJson::Tileset::forEachContent ( std::function< ForEachContentConstCallback > && callback) const
◆ forEachTile() [1/2]
void CesiumTilesetJson::Tileset::forEachTile ( std::function< ForEachTileCallback > && callback)
This will only invoke the callback for explicit tiles. It won't follow external tilesets or implicit tiles.
◆ forEachTile() [2/2]
void CesiumTilesetJson::Tileset::forEachTile ( std::function< ForEachTileConstCallback > && callback) const
◆ isExtensionRequired()
bool CesiumTilesetJson::Tileset::isExtensionRequired ( const std::string & extensionName) const
noexcept
extensionNameThe extension name to check.
True if the extension is found in extensionsRequired; otherwise, false.
◆ isExtensionUsed()
bool CesiumTilesetJson::Tileset::isExtensionUsed ( const std::string & extensionName) const
noexcept
True if the extension is found in extensionsUsed; otherwise, false.
◆ removeExtensionRequired()
void CesiumTilesetJson::Tileset::removeExtensionRequired ( const std::string & extensionName)
Calling this function also removes the extension from extensionsUsed.
◆ removeExtensionUsed()
void CesiumTilesetJson::Tileset::removeExtensionUsed ( const std::string & extensionName)
