Metadata about the tile's content and a link to the content.
More...
#include <CesiumTilesetJson/Content.h>
| | Calculates the size in bytes of this object, including the contents of all collections, pointers, and strings. This will NOT include the size of any extensions attached to the object. Calling this method may be slow as it requires traversing the object's entire structure.
| template<typename T> |
| | Checks if an extension exists given its static type.
| | Gets an extension given its static type.
| | Gets a generic extension with the given name as a CesiumUtility::JsonValue.
| template<typename T, typename... ConstructorArgumentTypes> |
| | Adds a statically-typed extension to this object.
| | Removes a statically-typed extension from this object.
| | Calculates the size in bytes of this ExtensibleObject, including all of its extras but NOT including its extensions. Calling this method may be slow as it requires traversing the entire object.
| std::optional< CesiumTilesetJson::BoundingVolume > | boundingVolume |
| | An optional bounding volume that tightly encloses tile content. tile.boundingVolume provides spatial coherence and tile.content.boundingVolume enables tight view frustum culling. When this is omitted, tile.boundingVolume is used.
| std::string | uri |
| | A uri that points to tile content. When the uri is relative, it is relative to the referring tileset JSON file.
| std::optional< CesiumTilesetJson::MetadataEntity > | metadata |
| | Metadata that is associated with this content.
| std::optional< int64_t > | group |
| | The group this content belongs to. The value is an index into the array of groups that is defined for the containing tileset.
| | The extensions attached to this object.
| | Application-specific data.
| | Unknown properties that exist on this object but do not have any representation in the statically-typed classes.
| static constexpr const char * | TypeName = "Content" |
| | The original name of this type.
Definition at line 18 of file Content.h.
◆ getSizeBytes()
| int64_t CesiumTilesetJson::Content::getSizeBytes |
const |
Definition at line 55 of file Content.h.
◆ boundingVolume
Definition at line 30 of file Content.h.
◆ group
| std::optional<int64_t> CesiumTilesetJson::Content::group |
Definition at line 47 of file Content.h.
◆ metadata
Definition at line 41 of file Content.h.
◆ TypeName
| const char* CesiumTilesetJson::Content::TypeName = "Content" |
Definition at line 22 of file Content.h.
◆ uri
| std::string CesiumTilesetJson::Content::uri |
Definition at line 36 of file Content.h.
- /home/runner/work/cesium-native/cesium-native/CesiumTilesetJson/generated/include/CesiumTilesetJson/Content.h
