CesiumTilesetJson::TilesetSpec Struct Reference
A 3D Tiles tileset. More...
#include <CesiumTilesetJson/TilesetSpec.h>
Inheritance diagram for CesiumTilesetJson::TilesetSpec:
CesiumUtility::ExtensibleObject CesiumTilesetJson::Tileset
CesiumTilesetJson::Asset asset
std::unordered_map< std::string, CesiumTilesetJson::Properties > properties
 A dictionary object of metadata about per-feature properties.
std::optional< CesiumTilesetJson::Schema > schema
 An object defining the structure of metadata classes and enums. When this is defined, then schemaUri shall be undefined.
std::optional< std::string > schemaUri
 The URI (or IRI) of the external schema file. When this is defined, then schema shall be undefined.
std::optional< CesiumTilesetJson::Statistics > statistics
 An object containing statistics about metadata entities.
std::vector< CesiumTilesetJson::GroupMetadata > groups
 An array of groups that tile content may belong to. Each element of this array is a metadata entity that describes the group. The tile content group property is an index into this array.
std::optional< CesiumTilesetJson::MetadataEntity > metadata
 A metadata entity that is associated with this tileset.
double geometricError = double()
 The error, in meters, introduced if this tileset is not rendered. At runtime, the geometric error is used to compute screen space error (SSE), i.e., the error measured in pixels.
CesiumTilesetJson::Tile root
 The root tile.
std::vector< std::string > extensionsUsed
 Names of 3D Tiles extensions used somewhere in this tileset.
std::vector< std::string > extensionsRequired
 Names of 3D Tiles extensions required to properly load this tileset. Each element of this array shall also be contained in extensionsUsed.
static constexpr const char * TypeName = "Tileset"
Protected Member Functions
 TilesetSpec ()=default
 This class is not meant to be instantiated directly. Use Tileset instead.
Friends
struct Tileset
A 3D Tiles tileset.
Definition at line 24 of file TilesetSpec.h.
int64_t CesiumTilesetJson::TilesetSpec::getSizeBytes ( ) const
Definition at line 99 of file TilesetSpec.h.
◆ Tileset
friend struct Tileset
friend
Definition at line 148 of file TilesetSpec.h.
◆ asset
CesiumTilesetJson::Asset CesiumTilesetJson::TilesetSpec::asset
Definition at line 34 of file TilesetSpec.h.
◆ extensionsRequired
std::vector<std::string> CesiumTilesetJson::TilesetSpec::extensionsRequired
Definition at line 91 of file TilesetSpec.h.
◆ extensionsUsed
std::vector<std::string> CesiumTilesetJson::TilesetSpec::extensionsUsed
Definition at line 85 of file TilesetSpec.h.
◆ geometricError
double CesiumTilesetJson::TilesetSpec::geometricError = double()
Definition at line 75 of file TilesetSpec.h.
◆ groups
std::vector<CesiumTilesetJson::GroupMetadata> CesiumTilesetJson::TilesetSpec::groups
Definition at line 63 of file TilesetSpec.h.
◆ metadata
std::optional<CesiumTilesetJson::MetadataEntity> CesiumTilesetJson::TilesetSpec::metadata
Definition at line 68 of file TilesetSpec.h.
◆ properties
std::unordered_map<std::string, CesiumTilesetJson::Properties> CesiumTilesetJson::TilesetSpec::properties
Definition at line 39 of file TilesetSpec.h.
◆ root
CesiumTilesetJson::Tile CesiumTilesetJson::TilesetSpec::root
The root tile.
Definition at line 80 of file TilesetSpec.h.
◆ schema
std::optional<CesiumTilesetJson::Schema> CesiumTilesetJson::TilesetSpec::schema
Definition at line 45 of file TilesetSpec.h.
◆ schemaUri
std::optional<std::string> CesiumTilesetJson::TilesetSpec::schemaUri
Definition at line 51 of file TilesetSpec.h.
◆ statistics
std::optional<CesiumTilesetJson::Statistics> CesiumTilesetJson::TilesetSpec::statistics
Definition at line 56 of file TilesetSpec.h.
const char* CesiumTilesetJson::TilesetSpec::TypeName = "Tileset"
Definition at line 29 of file TilesetSpec.h.
