More...
#include <CesiumTilesetJson/Asset.h>
| | Calculates the size in bytes of this object, including the contents of all collections, pointers, and strings. This will NOT include the size of any extensions attached to the object. Calling this method may be slow as it requires traversing the object's entire structure.
| template<typename T> |
| | Checks if an extension exists given its static type.
| | Gets an extension given its static type.
| | Gets a generic extension with the given name as a CesiumUtility::JsonValue.
| template<typename T, typename... ConstructorArgumentTypes> |
| | Adds a statically-typed extension to this object.
| | Removes a statically-typed extension from this object.
| | Calculates the size in bytes of this ExtensibleObject, including all of its extras but NOT including its extensions. Calling this method may be slow as it requires traversing the entire object.
| std::string | version |
| | The 3D Tiles version. The version defines the JSON schema for the tileset JSON and the base set of tile formats.
| std::optional< std::string > | tilesetVersion |
| | Application-specific version of this tileset, e.g., for when an existing tileset is updated.
| | The extensions attached to this object.
| | Application-specific data.
| | Unknown properties that exist on this object but do not have any representation in the statically-typed classes.
| static constexpr const char * | TypeName = "Asset" |
| | The original name of this type.
Definition at line 15 of file Asset.h.
◆ getSizeBytes()
| int64_t CesiumTilesetJson::Asset::getSizeBytes |
const |
Definition at line 40 of file Asset.h.
◆ tilesetVersion
| std::optional<std::string> CesiumTilesetJson::Asset::tilesetVersion |
Definition at line 32 of file Asset.h.
◆ TypeName
| const char* CesiumTilesetJson::Asset::TypeName = "Asset" |
Definition at line 20 of file Asset.h.
◆ version
| std::string CesiumTilesetJson::Asset::version |
Definition at line 26 of file Asset.h.
- /home/runner/work/cesium-native/cesium-native/CesiumTilesetJson/generated/include/CesiumTilesetJson/Asset.h
