CesiumTilesetJson::MetadataEntity Struct Reference
An object containing a reference to a class from a metadata schema, and property values that conform to the properties of that class. More...
#include <CesiumTilesetJson/MetadataEntity.h>
Inheritance diagram for CesiumTilesetJson::MetadataEntity:
CesiumUtility::ExtensibleObject CesiumTilesetJson::GroupMetadata
std::string classProperty
 The class that property values conform to. The value shall be a class ID declared in the classes dictionary of the metadata schema.
std::unordered_map< std::string, CesiumUtility::JsonValue > properties
 A dictionary, where each key corresponds to a property ID in the class' properties dictionary and each value contains the property values. The type of the value shall match the property definition: For BOOLEAN use true or false. For STRING use a JSON string. For numeric types use a JSON number. For ENUM use a valid enum name, not an integer value. For ARRAY, VECN, and MATN types use a JSON array containing values matching the componentType. Required properties shall be included in this dictionary.
static constexpr const char * TypeName = "MetadataEntity"
Definition at line 17 of file MetadataEntity.h.
int64_t CesiumTilesetJson::MetadataEntity::getSizeBytes ( ) const
Definition at line 48 of file MetadataEntity.h.
◆ classProperty
std::string CesiumTilesetJson::MetadataEntity::classProperty
Definition at line 28 of file MetadataEntity.h.
◆ properties
std::unordered_map<std::string, CesiumUtility::JsonValue> CesiumTilesetJson::MetadataEntity::properties
Definition at line 40 of file MetadataEntity.h.
const char* CesiumTilesetJson::MetadataEntity::TypeName = "MetadataEntity"
Definition at line 22 of file MetadataEntity.h.
