cesium-native 0.67.0
An object containing metadata about a group. More...
#include <CesiumTilesetJson/GroupMetadata.h>
Public Member Functions inherited from CesiumTilesetJson::MetadataEntity | |
| static constexpr const char * | TypeName = "GroupMetadata" |
Static Public Attributes inherited from CesiumTilesetJson::MetadataEntity | |
| static constexpr const char * | TypeName = "MetadataEntity" |
| std::string | classProperty |
The class that property values conform to. The value shall be a class ID declared in the classes dictionary of the metadata schema. | |
| std::unordered_map< std::string, CesiumUtility::JsonValue > | properties |
A dictionary, where each key corresponds to a property ID in the class' properties dictionary and each value contains the property values. The type of the value shall match the property definition: For BOOLEAN use true or false. For STRING use a JSON string. For numeric types use a JSON number. For ENUM use a valid enum name, not an integer value. For ARRAY, VECN, and MATN types use a JSON array containing values matching the componentType. Required properties shall be included in this dictionary. | |
Definition at line 12 of file GroupMetadata.h.
Definition at line 24 of file GroupMetadata.h.
Definition at line 16 of file GroupMetadata.h.
