cesium-native 0.67.0
The results of a QuantizedMeshLoader::load operation, containing either the loaded model, an improved bounding region for the tile, and available quadtree tiles discovered, if the load succeeded - or the request made and the errors that were returned, if the load failed. More...
#include <CesiumQuantizedMeshTerrain/QuantizedMeshLoader.h>
| std::optional< CesiumGltf::Model > | model |
| The glTF model to be rendered for this tile. | |
| std::optional< CesiumGeospatial::BoundingRegion > | updatedBoundingVolume {} |
| An improved bounding region for this tile. | |
| std::vector< CesiumGeometry::QuadtreeTileRectangularRange > | availableTileRectangles {} |
| Available quadtree tiles discovered as a result of loading this tile. | |
| std::shared_ptr< CesiumAsync::IAssetRequest > | pRequest |
| The request that was used to download the tile content, if any. | |
| CesiumUtility::ErrorList | errors |
| The errors and warnings reported while loading this tile. | |
Definition at line 31 of file QuantizedMeshLoader.h.
| std::vector<CesiumGeometry::QuadtreeTileRectangularRange> CesiumQuantizedMeshTerrain::QuantizedMeshLoadResult::availableTileRectangles {} |
Definition at line 54 of file QuantizedMeshLoader.h.
| CesiumUtility::ErrorList CesiumQuantizedMeshTerrain::QuantizedMeshLoadResult::errors |
Definition at line 66 of file QuantizedMeshLoader.h.
| std::optional<CesiumGltf::Model> CesiumQuantizedMeshTerrain::QuantizedMeshLoadResult::model |
If this is std::nullopt, the tile cannot be rendered. If it has a value but the model is blank, the tile can be "rendered", but it is rendered as nothing.
Definition at line 39 of file QuantizedMeshLoader.h.
| std::shared_ptr<CesiumAsync::IAssetRequest> CesiumQuantizedMeshTerrain::QuantizedMeshLoadResult::pRequest |
This field is only populated when there are request-related errors.
Definition at line 61 of file QuantizedMeshLoader.h.
| std::optional<CesiumGeospatial::BoundingRegion> CesiumQuantizedMeshTerrain::QuantizedMeshLoadResult::updatedBoundingVolume {} |
If this is available, then it is more accurate than the one the tile used originally.
Definition at line 47 of file QuantizedMeshLoader.h.
