CesiumQuantizedMeshTerrain::QuantizedMeshLoader Class Referencefinal
Loads quantized-mesh-1.0 terrain data. More...
#include <CesiumQuantizedMeshTerrain/QuantizedMeshLoader.h>
static QuantizedMeshLoadResult load (const CesiumGeometry::QuadtreeTileID &tileID, const CesiumGeospatial::BoundingRegion &tileBoundingVolume, const std::string &url, const std::span< const std::byte > &data, bool enableWaterMask, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84)
 Create a QuantizedMeshLoadResult from the given data.
static QuantizedMeshMetadataResult loadMetadata (const std::span< const std::byte > &data, const CesiumGeometry::QuadtreeTileID &tileID)
 Parses the metadata (tile availability) from the given quantized-mesh terrain tile data.
static QuantizedMeshMetadataResult loadAvailabilityRectangles (const rapidjson::Document &layerJson, uint32_t startingLevel)
 Extracts tile availability information from a parsed layer.json or tile metadata extension.
Definition at line 88 of file QuantizedMeshLoader.h.
◆ load()
static QuantizedMeshLoadResult CesiumQuantizedMeshTerrain::QuantizedMeshLoader::load ( const CesiumGeometry::QuadtreeTileID & tileID,
const CesiumGeospatial::BoundingRegion & tileBoundingVolume,
const std::string & url,
const std::span< const std::byte > & data,
static
tileIDThe tile ID.
tileBoundingVolumeThe tile bounding volume.
urlThe URL from which the data was loaded.
dataThe actual tile data.
enableWaterMaskIf true, will attempt to load a water mask from the quantized mesh data.
ellipsoidThe ellipsoid to use for this quantized mesh.
The QuantizedMeshLoadResult
◆ loadAvailabilityRectangles()
static QuantizedMeshMetadataResult CesiumQuantizedMeshTerrain::QuantizedMeshLoader::loadAvailabilityRectangles ( const rapidjson::Document & layerJson,
uint32_t startingLevel )
static
The actual availability information will be found in a property called available.
layerJsonThe RapidJSON document containing the layer.json.
startingLevelThe first tile level number to which the availability information applies.
The availability.
◆ loadMetadata()
static QuantizedMeshMetadataResult CesiumQuantizedMeshTerrain::QuantizedMeshLoader::loadMetadata ( const std::span< const std::byte > & data,
const CesiumGeometry::QuadtreeTileID & tileID )
static
tileIDThe tile ID.
The parsed metadata.
