CesiumGltf::ExtensionModelExtStructuralMetadata Struct Referencefinal
glTF extension that provides structural metadata about vertices, texels, and features in a glTF asset. More...
#include <CesiumGltf/ExtensionModelExtStructuralMetadata.h>
Inheritance diagram for CesiumGltf::ExtensionModelExtStructuralMetadata:
CesiumUtility::IntrusivePointer< CesiumGltf::Schema > schema
std::optional< std::string > schemaUri
 The URI (or IRI) of the external schema file.
std::vector< CesiumGltf::PropertyTable > propertyTables
 An array of property table definitions, which may be referenced by index.
std::vector< CesiumGltf::PropertyTexture > propertyTextures
 An array of property texture definitions, which may be referenced by index.
std::vector< CesiumGltf::PropertyAttribute > propertyAttributes
 An array of property attribute definitions, which may be referenced by index.
std::optional< CesiumGltf::Statistics > statistics
 An object containing statistics about metadata entities.
static constexpr const char * TypeName = "ExtensionModelExtStructuralMetadata"
static constexpr const char * ExtensionName = "EXT_structural_metadata"
Definition at line 23 of file ExtensionModelExtStructuralMetadata.h.
int64_t CesiumGltf::ExtensionModelExtStructuralMetadata::getSizeBytes ( ) const
Definition at line 72 of file ExtensionModelExtStructuralMetadata.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionModelExtStructuralMetadata::ExtensionName = "EXT_structural_metadata"
Definition at line 31 of file ExtensionModelExtStructuralMetadata.h.
◆ propertyAttributes
std::vector<CesiumGltf::PropertyAttribute> CesiumGltf::ExtensionModelExtStructuralMetadata::propertyAttributes
Definition at line 59 of file ExtensionModelExtStructuralMetadata.h.
◆ propertyTables
std::vector<CesiumGltf::PropertyTable> CesiumGltf::ExtensionModelExtStructuralMetadata::propertyTables
Definition at line 47 of file ExtensionModelExtStructuralMetadata.h.
◆ propertyTextures
std::vector<CesiumGltf::PropertyTexture> CesiumGltf::ExtensionModelExtStructuralMetadata::propertyTextures
Definition at line 53 of file ExtensionModelExtStructuralMetadata.h.
◆ schema
CesiumUtility::IntrusivePointer<CesiumGltf::Schema> CesiumGltf::ExtensionModelExtStructuralMetadata::schema
Definition at line 36 of file ExtensionModelExtStructuralMetadata.h.
◆ schemaUri
std::optional<std::string> CesiumGltf::ExtensionModelExtStructuralMetadata::schemaUri
Definition at line 41 of file ExtensionModelExtStructuralMetadata.h.
◆ statistics
std::optional<CesiumGltf::Statistics> CesiumGltf::ExtensionModelExtStructuralMetadata::statistics
Definition at line 64 of file ExtensionModelExtStructuralMetadata.h.
const char* CesiumGltf::ExtensionModelExtStructuralMetadata::TypeName = "ExtensionModelExtStructuralMetadata"
Definition at line 28 of file ExtensionModelExtStructuralMetadata.h.
