Properties conforming to a class, organized as property values stored in binary columnar arrays. More...
#include <CesiumGltf/PropertyTable.h>
| The name of the property table, e.g. for display purposes. | |
| std::string | classProperty |
The class that property values conform to. The value must be a class ID declared in the classes dictionary. | |
| int64_t | count = int64_t() |
| The number of elements in each property array. | |
| std::unordered_map< std::string, CesiumGltf::PropertyTableProperty > | properties |
A dictionary, where each key corresponds to a property ID in the class' properties dictionary and each value is an object describing where property values are stored. Required properties must be included in this dictionary. | |
| static constexpr const char * | TypeName = "PropertyTable" |
Definition at line 19 of file PropertyTable.h.
Definition at line 56 of file PropertyTable.h.
| std::string CesiumGltf::PropertyTable::classProperty |
Definition at line 35 of file PropertyTable.h.
| int64_t CesiumGltf::PropertyTable::count = int64_t() |
Definition at line 40 of file PropertyTable.h.
| std::optional<std::string> CesiumGltf::PropertyTable::name |
Definition at line 29 of file PropertyTable.h.
| std::unordered_map<std::string, CesiumGltf::PropertyTableProperty> CesiumGltf::PropertyTable::properties |
Definition at line 48 of file PropertyTable.h.
Definition at line 24 of file PropertyTable.h.
