Parameters describing an implicit shape. More...
#include <CesiumGltf/ExtensionKhrImplicitShapesShape.h>
Classes | |
| struct | Type |
| Known values for Specifies the shape type. More... | |
Public Member Functions inherited from CesiumGltf::NamedObject | |
| Calculates the size in bytes of this object, including the contents of all collections, pointers, and strings. Calling this method may be slow as it requires traversing the object's entire structure. | |
| std::string | type = Type::sphere |
| Specifies the shape type. | |
| std::optional< CesiumGltf::ExtensionKhrImplicitShapesSphere > | sphere |
| A set of parameter values that are used to define a sphere shape. | |
| std::optional< CesiumGltf::ExtensionKhrImplicitShapesBox > | box |
| A set of parameter values that are used to define a box shape. | |
| std::optional< CesiumGltf::ExtensionKhrImplicitShapesCapsule > | capsule |
| A set of parameter values that are used to define a capsule shape. | |
| std::optional< CesiumGltf::ExtensionKhrImplicitShapesCylinder > | cylinder |
| A set of parameter values that are used to define a cylinder shape. | |
Public Attributes inherited from CesiumGltf::NamedObject | |
| std::string | name |
| The user-defined name of this object. | |
| static constexpr const char * | TypeName = "ExtensionKhrImplicitShapesShape" |
Definition at line 19 of file ExtensionKhrImplicitShapesShape.h.
Definition at line 83 of file ExtensionKhrImplicitShapesShape.h.
| std::optional<CesiumGltf::ExtensionKhrImplicitShapesBox> CesiumGltf::ExtensionKhrImplicitShapesShape::box |
Definition at line 65 of file ExtensionKhrImplicitShapesShape.h.
| std::optional<CesiumGltf::ExtensionKhrImplicitShapesCapsule> CesiumGltf::ExtensionKhrImplicitShapesShape::capsule |
Definition at line 70 of file ExtensionKhrImplicitShapesShape.h.
| std::optional<CesiumGltf::ExtensionKhrImplicitShapesCylinder> CesiumGltf::ExtensionKhrImplicitShapesShape::cylinder |
Definition at line 75 of file ExtensionKhrImplicitShapesShape.h.
| std::optional<CesiumGltf::ExtensionKhrImplicitShapesSphere> CesiumGltf::ExtensionKhrImplicitShapesShape::sphere |
Definition at line 60 of file ExtensionKhrImplicitShapesShape.h.
| std::string CesiumGltf::ExtensionKhrImplicitShapesShape::type = Type::sphere |
Definition at line 55 of file ExtensionKhrImplicitShapesShape.h.
Definition at line 24 of file ExtensionKhrImplicitShapesShape.h.
