Parameters describing a cylinder shape. More...
#include <CesiumGltf/ExtensionKhrImplicitShapesCylinder.h>
| double | height = 0.5 |
| The height of the cylinder, centered along the Y axis. | |
| double | radiusBottom = 0.25 |
| The radius of the bottom of the cylinder (the disk located along -Y.) | |
| double | radiusTop = 0.25 |
| The radius of the top of the cylinder (the disk located along +Y.) | |
| static constexpr const char * | TypeName = "ExtensionKhrImplicitShapesCylinder" |
Definition at line 12 of file ExtensionKhrImplicitShapesCylinder.h.
Definition at line 41 of file ExtensionKhrImplicitShapesCylinder.h.
| double CesiumGltf::ExtensionKhrImplicitShapesCylinder::height = 0.5 |
Definition at line 22 of file ExtensionKhrImplicitShapesCylinder.h.
| double CesiumGltf::ExtensionKhrImplicitShapesCylinder::radiusBottom = 0.25 |
Definition at line 28 of file ExtensionKhrImplicitShapesCylinder.h.
| double CesiumGltf::ExtensionKhrImplicitShapesCylinder::radiusTop = 0.25 |
Definition at line 33 of file ExtensionKhrImplicitShapesCylinder.h.
Definition at line 17 of file ExtensionKhrImplicitShapesCylinder.h.
