Parameters describing a capsule shape. More...
#include <CesiumGltf/ExtensionKhrImplicitShapesCapsule.h>
| double | height = 0.5 |
| The distance between the centers of the two capping spheres of capsule. | |
| double | radiusBottom = 0.25 |
| The radius of the sphere located at the bottom of the capsule (i.e. the sphere at the half-height along -Y) | |
| double | radiusTop = 0.25 |
| The radius of the sphere located at the top of the capsule (i.e. the sphere at the half-height along +Y) | |
| static constexpr const char * | TypeName = "ExtensionKhrImplicitShapesCapsule" |
Definition at line 12 of file ExtensionKhrImplicitShapesCapsule.h.
Definition at line 43 of file ExtensionKhrImplicitShapesCapsule.h.
| double CesiumGltf::ExtensionKhrImplicitShapesCapsule::height = 0.5 |
Definition at line 23 of file ExtensionKhrImplicitShapesCapsule.h.
| double CesiumGltf::ExtensionKhrImplicitShapesCapsule::radiusBottom = 0.25 |
Definition at line 29 of file ExtensionKhrImplicitShapesCapsule.h.
| double CesiumGltf::ExtensionKhrImplicitShapesCapsule::radiusTop = 0.25 |
Definition at line 35 of file ExtensionKhrImplicitShapesCapsule.h.
Definition at line 17 of file ExtensionKhrImplicitShapesCapsule.h.
