Parameters describing a box shape. More...
#include <CesiumGltf/ExtensionKhrImplicitShapesBox.h>
| std::vector< double > | size = {1, 1, 1} |
| The extents of the box in each axis in local space. | |
| static constexpr const char * | TypeName = "ExtensionKhrImplicitShapesBox" |
Definition at line 14 of file ExtensionKhrImplicitShapesBox.h.
Definition at line 32 of file ExtensionKhrImplicitShapesBox.h.
| std::vector<double> CesiumGltf::ExtensionKhrImplicitShapesBox::size = {1, 1, 1} |
Definition at line 24 of file ExtensionKhrImplicitShapesBox.h.
Definition at line 19 of file ExtensionKhrImplicitShapesBox.h.
