Cesium3DTiles::Tile::Refine Struct Reference
Known values for Specifies if additive or replacement refinement is used when traversing the tileset for rendering. This property is required for the root tile of a tileset; it is optional for all other tiles. The default is to inherit from the parent tile. More...
#include <Cesium3DTiles/Tile.h>
static const std::string ADD = "ADD"
 ADD
static const std::string REPLACE = "REPLACE"
 REPLACE
Definition at line 32 of file Tile.h.
◆ ADD
const std::string Cesium3DTiles::Tile::Refine::ADD = "ADD"
inlinestatic
ADD
Definition at line 34 of file Tile.h.
◆ REPLACE
const std::string Cesium3DTiles::Tile::Refine::REPLACE = "REPLACE"
inlinestatic
REPLACE
Definition at line 37 of file Tile.h.
