cesium-native 0.67.0
Classes for loading vector data such as GeoJSON. More...
Classes | |
| struct | ColorStyle |
| Specifies the color of a style type. More... | |
| struct | ConstGeoJsonObjectIterator |
The const equivalent of GeoJsonObjectIterator. More... | |
| struct | ConstGeoJsonObjectTypeIterator |
An iterator over all GeoJsonObject objects that contain a value of type ObjectType. More... | |
| struct | ConstGeoJsonPrimitiveIterator |
| Returns all geometry data of a given type from a GeoJsonObject. More... | |
| class | GeoJsonDocument |
| A vector document parsed from GeoJSON. More... | |
| struct | GeoJsonFeature |
A GeoJsonFeature object represents a spatially bounded "thing." It is a collection of information that is possibly linked to a geometry object. More... | |
| struct | GeoJsonFeatureCollection |
A FeatureCollection represents any number of GeoJsonFeature objects. More... | |
| struct | GeoJsonGeometryCollection |
A GeometryCollection represents any number of GeoJsonObject objects. More... | |
| struct | GeoJsonLineString |
A LineString geometry object. More... | |
| struct | GeoJsonMultiLineString |
A MultiLineString geometry object. More... | |
| struct | GeoJsonMultiPoint |
A MultiPoint geometry object. More... | |
| struct | GeoJsonMultiPolygon |
| A 'MultiPolygon' geometry object. More... | |
| struct | GeoJsonObject |
| An object in a GeoJSON document. More... | |
| struct | GeoJsonObjectIterator |
| Iterates over a GeoJsonObject and all of its children. More... | |
| struct | GeoJsonPoint |
A Point geometry object. More... | |
| struct | GeoJsonPolygon |
A Polygon geometry object. More... | |
| class | GltfConverter |
| Convert GeoJSON documents to glTF. More... | |
| struct | LineStyle |
| The style used to draw polylines and strokes. More... | |
| struct | PointStyle |
| The style used to draw a point. More... | |
| struct | PolygonStyle |
| The style used to draw a Polygon. More... | |
| struct | VectorDocumentAttribution |
| Attribution that must be included with a vector document. More... | |
| class | VectorRasterizer |
| Rasterizes vector primitives into a CesiumImage::ImageAsset. More... | |
| struct | VectorStyle |
| Style information to use when drawing vector data. More... | |
Typedefs | |
| using | ConstGeoJsonPointIterator |
An iterator over all Point and MultiPoint objects in and including a root GeoJSON object. | |
| using | ConstGeoJsonLineStringIterator |
An iterator over all LineString and MultiLineString objects in and including a root GeoJSON object. | |
| using | ConstGeoJsonPolygonIterator |
An iterator over all Polygon and MultiPolygon objects in and including a root GeoJSON object. | |
| using | GeoJsonObjectVariant |
| Every possible object that can be specified in a GeoJSON document. | |
| using | ConverterResult = CesiumUtility::Result<CesiumGltf::Model> |
| The result of converting a GeoJSON document to glTF. | |
| using | ConvertSchemaResult |
| The result of converting a MAXAR_content_geojson schema to a glTF schema. | |
Enumerations | |
| enum class | GeoJsonObjectType : uint8_t { Point = 0 , MultiPoint = 1 , LineString = 2 , MultiLineString = 3 , Polygon = 4 , MultiPolygon = 5 , GeometryCollection = 6 , Feature = 7 , FeatureCollection = 8 } |
| A type of object in GeoJson data. More... | |
| enum class | ColorMode : uint8_t { Normal = 0 , Random = 1 } |
| The mode used for coloring. More... | |
| enum class | LineWidthMode : uint8_t { Pixels = 0 , Meters = 1 } |
| The mode to use when interpreting a given line width. More... | |
Functions | |
| std::string_view | geoJsonObjectTypeToString (GeoJsonObjectType type) |
Returns the name of a GeoJsonObjectType value. | |
Definition at line 28 of file GeoJsonObject.h.
Definition at line 22 of file GeoJsonObject.h.
Definition at line 36 of file GeoJsonObject.h.
Definition at line 18 of file GltfConverter.h.
Definition at line 24 of file GltfConverter.h.
Definition at line 423 of file GeoJsonObjectTypes.h.
strong |
Definition at line 13 of file VectorStyle.h.
strong |
Definition at line 19 of file GeoJsonObjectTypes.h.
strong |
Definition at line 56 of file VectorStyle.h.
